SBC Main bearing size
On very high HP (1000+) sbc does the main bearing size between 350 and 400 ? Oldhead
Quicker then most
Re: SBC Main bearing size
On very high HP (1000+) sbc does the main bearing size between 350 and 400 make a difference?
Is it making that horsepower normally aspirated at very high RPM, from nitrous or from forced induction at lower RPM?
the overlap between the rod and main journals with the larger mains may keep the crank from flexing as that is why GM made the larger 400 mains larger
