You won't need to take advantage of the main advantage EFI gives you, the ability to quickly and easily tune the engine's entire operating spectrum, from closed throttle to WOT, 800rpm to 8000rpm, -50F to 250F coolant temps, and so forth. You don't need crisp drivability when putting around town at 3% throttle and 1200rpm in gear like EFI can give you.WeingartnerRacing wrote: ↑Sat Mar 24, 2018 2:42 pmAlrighty quote me a good step like fuel tech or Holley dominator to run a tunnel ram two carbs on methanol. That’s what my new motor is going to be. It is a bbc should make around a 1000hp. The carbs are going to cost me $2200, that’s for two of them, ice ignition about $1000, and grid $350, I already have a rpm data logger that cost me $1500 and that was with dash. It does water temp, oil pressure, engine rpm and driveshaft rpm. If you can get within a $1000 of this I would buy it.andyf wrote: ↑Sat Mar 24, 2018 12:34 pmSounds like you don't have much experience with EFI. I'm doing a new EFI car right now and EFI is easier and less expensive to install from the ground up. Apples to applies EFI is less expensive since you don't need to piece together all the little parts to crutch a carb + distributor type of system.WeingartnerRacing wrote: ↑Sat Mar 24, 2018 10:26 am It may be 2018 but carbs still run as good or better than efi and cost thousands less. I think the efi thing is a fad cool thing so people can say they are a tuner and have the latest technology. It’s like the guy that has to have the latest smart phone. Then months later realizing the thing cost a lot more than the old one and isn’t much better.
Since it’s 2018 the one thing that has changed is most engines now have a power adder. Na heads up racing is almost none existent. Due to this efi has become necessary because carbs don’t work as well with boost set ups.
I wish efi was cheaper, and please don’t say stock ecm or some cheap equivalent is fine. Most just include some pieces in the cost but not all. You have ecm $1200, wiring harness $500, injectors$1000, o2 sensors $200, other sensors $300, throttle body $600 and that is no ignition pieces and on the cheap side. Efi done right is expensive.
That's actually a big downside for the casual hobbyist. They want a nasty sounding engine and then EFI makes it run like a Camry, which makes them unhappy. My car idles at maybe 4" of vacuum at 1500rpm. It has near impeccable drivability. I can actually get it to idle down to 900rpm if I wanted but then it's running at maybe an inch of vacuum just to stay running and throttle response is a bit soggy
