Valve float issues on dyno
lekid
Re: Valve float issues on dyno
Post by lekid »
Not same fuel on other engine. Quench is 0.080" and 13.0 static compression. Engine wanted 35deg.
Did not miss or breakup until 7100rpm
user-17438
Post by user-17438 »
So did you check the plugs? Rich up top lean up top? Is it a nitrous carb?
lekid
Post by lekid »
We checked the plugs, they looked a little lean but still had some fuel on them
zums
Post by zums »
Ive run that exact seat and open pressure on a 2.08 to 9700 but without knowing weigh its irrelevant, if your checking springs on the engine you need to know what percentage different your hand checker reads verse the bench checker, while you are doing that i would at least take 1 intake spring off and look real good at the locks, retainer, valve stem and spring
Tom
CamKing
Post by CamKing »
If it's a std cam journal size, the base circle has to be below .900". If so, ht's flexing all over the place with those spring pressures.
The other thing I would look at, is if the pushrods are flexing. what diameter and wall thickness are you running?
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
lekid
Post by lekid »
Had a good discussion with Chris Uratchko and he could not agree that it was valve float. He believes that it is the crank trigger sensor causing that issue.
I checked the resistance and Inget 7 ohms. MSD says that it should be between 65-85 ohms. Could that be the problem? That simple?
JoePorting
Post by JoePorting »
IMO, the new cam is too big. I'd go back to the old cam, or maybe consider a cam even smaller like around .650/250.
Joe Facciano
fdicrasto
Post by fdicrasto »
I would not trust ANY spring checker until, as previously suggested, it was calibrated to a good bench spring tester. Could you have a broken inner spring? Those valve springs should be adequate for your set up if installed to spec. Also as MT mentioned, need to post the dyno sheet to look over other parameters for a clue as to what could be the issue.
af2
Post by af2 »
JoePorting wrote: Thu Mar 15, 2018 6:38 pm IMO, the new cam is too big. I'd go back to the old cam, or maybe consider a cam even smaller like around .650/250.
Why the drop in lift? Am I missing something?
A set of springs is all that is needed....
GURU is only a name.
af2
Post by af2 »
[quote=lekid post_id=724654 time=1521152032 user_id=12696
[/quote]
I doubt it but the easiest part change......
JoePorting
af2 wrote: Thu Mar 15, 2018 7:57 pm
I think a more stable valve train is more important than a few more hp. I'm guessing a smaller cam would actually make more power, or at worse, about the same. Also, a 2.10 valve doesn't flow much more past .600" lift.
Joe Facciano
user-17438
JoePorting wrote: Thu Mar 15, 2018 10:13 pm
Are you serious dude?
user-30257
Post by user-30257 »
CamKing wrote: Thu Mar 15, 2018 2:42 pm If it's a std cam journal size, the base circle has to be below .900". If so, ht's flexing all over the place with those spring pressures.
Or maybe the pushrods are binding somewhere. Have you consulted with the engine builder? Or cyliner head guy?
user-17438
lekid wrote: Thu Mar 15, 2018 1:53 pm We checked the plugs, they looked a little lean but still had some fuel on them
Did you add jet? Did you pull timing?
What all did you guys do at the dyno facility?
Could you post everything you tested and tried? So you could help us help you.
Did the dyno operator test it at 300rpm/sec vs 600rpm/sec. If so did it rpm more at the higher test rate?
There are so many things that could make a graph look like that. Yet all the data you should have to verify anything is missing.
Warp Speed
Post by Warp Speed »
MTENGINES wrote: Thu Mar 15, 2018 10:21 pm
I believe he is! Lol
