Cryogenic rocker treatment
bigfoot
Post by bigfoot »
We have to run stock steel rocker arms on our sb ford in oval track racing..if l get them treated with the cryogenic treatment with it make them last longer ??
jed
Re: Cryogenic rocker treatment
Post by jed »
Yes
pamotorman
Post by pamotorman »
make sure they get plenty of oil as that is what cools them.
cgarb
Post by cgarb »
Could you have the rockers salt nitride coated? They use that in firearms applications and from what I gather its similar to having aluminum anodized. A hard surface treatment that resists corrosion and wear. Might be something to look into.
resurrectionjoe
Post by resurrectionjoe »
RW TECH
Post by RW TECH »
All the cryogenic treatment "might" do is stress relieve the part. It is NOT a hardening process.
If the part was already stress-relieved when it was made, expect a zero change.
groberts101
Post by groberts101 »
RW TECH wrote: Thu Mar 15, 2018 7:35 am All the cryogenic treatment "might" do is stress relieve the part. It is NOT a hardening process.
Hmmm?.. are these stamped STEEL.. or cast iron rockers?
Cryo does nothing to promote the transformation of retained austenite present in heat treated steels into harder martensite steel? Also has nothing to do with hardening due to carbide precipitation?
Dammit!.. sure wish I would have known this before wasting all my money cryo treating cutting tools lawn mover blades and engine parts! Must be a placebo affect cause I thought my junk was lasting longer. #-o
F-BIRD'88
Post by F-BIRD'88 »
The cryo may help the rockers but easy break in with reduced spring pressure + add some moly to the oil and ensure LOTS of oil flow over the rocker so it gets to the ball.
Run it break it in just like a solid flat tappet camshaft break in and then add the racing spring pressure.
This allows the rocker and ball to create a seat in the rocker without excess heat and pressure.
This alos work hardens the seat in the rocker where the ball runs.
until this seat in the new rocker is established there is a lot of friction and heat.
The moly and lots of oil flow keeps the new rocker from over heating and being torn up
www.molyslip.com Molyslip E oil supplement.
It is the same deal as new racing flat tappet cam break in.
blykins
Post by blykins »
You can also run the trays that sit on top of the rockers. The oil ends up shooting out of the rockers under pressure and the tray/tin reflects it right back down on the rocker arms.
Lykins Motorsports
brent@lykinsmotorsports.com
www.lykinsmotorsports.com
www.customfordcams.com
autogear
Vendor
Post by autogear »
what about REM polishing or its cousin Keramo finishing? Perhaps this AND cryo? Whoever does your polishing needs a fairly small dia. for the ceramic media. I suppose you could hand polish them instead
digger
Post by digger »
Polish then shot peen
bigfoot
Post by bigfoot »
Thanks resurrectionjoe,,,,a friend used the Elgin rockers on his ford and had good luck,,,, the sb Chev rocker with 7 /16 stud,,, ice 411840SP....it will work on a sb ford ?? Right
pamotorman
blykins wrote: Thu Mar 15, 2018 1:50 pm You can also run the trays that sit on top of the rockers. The oil ends up shooting out of the rockers under pressure and the tray/tin reflects it right back down on the rocker arms.
you can also use "kool nuts" like GM use on their crate track engines. http://www.jegs.com/i/Crane-Cams/271/99 ... RkQAvD_BwE
Post by MadBill »
The slotted rocker balls as in the Competition Products kits get mixed reviews: better oil access but less contact area.. :-k
midnightbluS10
Post by midnightbluS10 »
resurrectionjoe wrote: Thu Mar 15, 2018 6:58 am http://www.competitionproducts.com/mobi ... ucts/2255/
Maybe elgin has Ford rockers also
They do but they're not long slot rockers. 7/16" stud and 1.6 ratio
ICE410888 - 302 Boss, 351C, 429
ICE410889 - 302(exc Boss), 351W
http://www.elginind.com/prostock-catalog/
JC -
