Comp QXI Lobes
RevTheory
Comp QXI Lobes
Post by RevTheory » Tue Mar 13, 2018 11:09 am
Do you guys have any experience with QXI, hyd/roller lobes that you can share? Are they noisy? Do they crash the valvetrain? Mike Jones mentioned years ago that a lot of Comp grinds were like opening the valves with a hammer.
I'm thinking of a SBC with 1.7 rockers here. 225 @ .050, .651 lift.
CGT
Re: Comp QXI Lobes
Post by CGT » Tue Mar 13, 2018 11:29 am
Comp certainly has that reputation of noisy hydraulic roller lobes. . And I have heard plenty of them. Can't stand it. Mostly due in part to their XE, XER, XFI, LSK, type lobes. I have specced a few cams recently from them, that were decently quiet and stable using HUC, Marine, Marine high lift, magnum and I believe maybe HLO etc.
The "quietest" hydraulic rollers that I have gotten in the past used Bullet lobes.
blykins
Re: Comp QXI Lobes
Post by blykins » Tue Mar 13, 2018 1:01 pm
I haven't used the QXI lobes, but I've used the QXX and HUC lobes. They are quiet and did quite well.
The Thumpr lobes are also quiet.
XE and XFI lobes sound like a sewing machine.
Harvey Crane coined the term, "intensity".....hydraulic intensity with hydraulic cams or major intensity with solid cams, if I remember correctly.
That term has served me well over the years and it's simply just the difference between advertised duration and .050" duration. Now, don't get me wrong, there are many variables going into this that have to be eyeballed (lift, .200" duration, valvetrain weight, etc.), but in terms of hydraulic roller lobes, lobes with 55-56°(and up) of hydraulic intensity have proven to be quiet and easy on the valvetrain for me.
Lykins Motorsports
brent@lykinsmotorsports.com
www.lykinsmotorsports.com
RevTheory
Re: Comp QXI Lobes
Post by RevTheory » Tue Mar 13, 2018 1:30 pm
That's what I was wondering. This sounds like a pretty aggressive lobe and even Comp told me that the XFI were noisy. I sure like the area but I don't like the idea of the valves snapping shut to the point where you can actually hear it.
I'm eyeballing a Bullet grind that appears to be similar but Bullet doesn't group their profiles. At least Comp lies to me, lol
Bullet HR279/3823 279 224 147 .3823 CRA .649 1.7
vs.
Comp Cams QXI 13445 277 225 146 .383 .575 .613 .651 1.7 rocker
Thinking of QXX lobes on the exhaust.
blykins
Re: Comp QXI Lobes
Post by blykins » Tue Mar 13, 2018 1:43 pm
My gut says that QXI lobe will be noisy.
How about a Thumpr intake lobe? Or a QXX intake lobe?
Also, a more aggressive lobe with more area under the curve doesn't always make more hp/torque.
Lykins Motorsports
RevTheory
Re: Comp QXI Lobes
Post by RevTheory » Tue Mar 13, 2018 1:50 pm
Everything is on the table right now.
blykins
Re: Comp QXI Lobes
Post by blykins » Tue Mar 13, 2018 2:00 pm
What engine is this for? If you're working with lighter valve train, then you have some lee-way.
Lykins Motorsports
CamKing
Re: Comp QXI Lobes
Post by CamKing » Tue Mar 13, 2018 2:46 pm
Quiet
HR70375: 280@.006", 227@.050", 148@.200", .375" Lobe Lift
Kinda Quiet
HR70340: 272@.006", 224@.050", 147@.200", .340" Lobe Lift
HR71360: 276@.006", 228@.050", 151@.200", .360" Lobe Lift
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
Walter R. Malik
Re: Comp QXI Lobes
Post by Walter R. Malik » Tue Mar 13, 2018 5:54 pm
A LOT of the noisyness people hear is from using their trash hydraulic roller lifters.
groberts101
Re: Comp QXI Lobes
Post by groberts101 » Tue Mar 13, 2018 6:03 pm
Quiet
Kinda Quiet
Sorry to be the needy guy here, Mike.. what about listing a "kinda noisy" lobe spec?
groberts101
Re: Comp QXI Lobes
Post by groberts101 » Tue Mar 13, 2018 6:05 pm
Yep.. heard many swaps in both directions through the years. Lots of trashy sounding roller rockers out there too!
GARY C
Re: Comp QXI Lobes
Post by GARY C » Tue Mar 13, 2018 8:30 pm
Noisy must be faster, Pete Jackson marked a gear drive based on it's sound.
I found if you turn up the volume on your stereo it makes the noise go away. :)
CamKing
Re: Comp QXI Lobes
Post by CamKing » Wed Mar 14, 2018 10:11 am
Quiet
Kinda Quiet
Kinda quiet = kinda noisy
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
Orr89rocz
Re: Comp QXI Lobes
Post by Orr89rocz » Wed Mar 14, 2018 11:08 am
Its all in the ears of the beholder...
The faster looking lobes seem to be sewing machine like
Lifter tick can be prevalent in some setups as well but i have not had any problems with gm lifters or the sbc morel 4602’s despite the many claims they are noisy
I have run a jones 292 - 232 .353 lobe hyd roller in my sbc turbo car and it was quiet. But thats a relatively mild lobe imo
I ran a comp magnum hi lift lobe 306 246 .400 lobe in my other turbo combo with morel lifters and it also was relatively quiet imo. I had some minor pushrod rub on the head that ticked somewhat and my injectors ticked abit so hard to tell exactly. Slight sewing machine sound but nothing like xfi lobes i have heard
CGT
Re: Comp QXI Lobes
Post by CGT » Wed Mar 14, 2018 11:44 am
Just curious, In your guy's opinion. What is making the sewing machine noise? Is in the lifter, valves opening, closing? Im always left wondering, if they sound that raunchy...maybe your not even getting "all" of that mean lobe to begin with. I just stay away from those type lobes nowadays.
