Ring selection for street sbc
gnicholson
Post by gnicholson » Sun Mar 11, 2018 1:16 am
Im freshening an 11 to 1 street sbc with 4.200 bore diamond pistons. 1/16 1/16 3/16 . If i was starting over i would go with a thinner ring pack. This engine has a moroso 3 vane vacuum pump. Im thinking std moly filled top napier 2nd and std tension oil rings. Thought I would get some expert opinions on what rings I should use in this application
gnicholson
Re: Ring selection for street sbc
Post by gnicholson » Sun Mar 11, 2018 5:08 pm
I guess what i would like to know is what tension oil rings would you run with a vacuum pump on the street. This is not a daily driver but will be driven a fair amount and i would like to keep oil consumption to a minimum. Also is a napier 2nd ring a good idea on a street car . I would say this thing will see 1 to 2k a year.
1972ho
Post by 1972ho » Sun Mar 11, 2018 5:17 pm
Why not call a couple of the piston companies or total seal see what they have to say,but for me if it not a race only and trying to get max hp I would just go with the standard tension ring pack I would even get rid of the vacuum pump.
groberts101
Post by groberts101 » Sun Mar 11, 2018 5:46 pm
Probably a bit biased here, but I like the medium tension stuff(sometimes grouped into the "low tension" catagory) for vac assisted street/strip type deals. Yeah you give up some extra power to parasitic losses but a clean combustion space still counts for something too.
I also like gapless rings since you end up with less blowby and may potentially find even more power by reducing pump requirements/drag. The total seal AP top rings are pricy but will worth it over the long haul.
However, with your much lower % street type deal I'd probably lean towards file fitting a medium tension set to end up with something in between a low and medium tension. Then adjust vac if needed from there. Little extra margin would be prudent, IMHO.
EDIT: sorry.. crossed some wires when commenting on street use%.
cpmotors
Post by cpmotors » Sun Mar 11, 2018 9:09 pm
I run 8-11lb oil rings, Napier 2nd and AP steel or Moly faced with no issues on street cars, none with vacuum pumps though.
Not a fan of gapless rings.
Pete Graves
CPMotorworks,Inc.
Custom Engine Machining
Cylinder Head Fixture for Vertical / Surfacing Mills
engineguyBill
Post by engineguyBill » Sun Mar 11, 2018 11:25 pm
Go with ductile plasma moly (sprayed) top ring, Napier second and standard tension oil ring assembly for your application. "Moly filled" top ring typically uses a grey cast iron ring material which is very inferior compared to the ductile iron high performance top ring. Even better would be a nitrided or PVD steel top ring, but these are harder to find for 1/16" thickness rings. There is no benefit/advantage to using low tension oil ring assembly in a street-driven application.
Bill
SAE Member (28+ years)
- Theodore Roosevelt
In-Tech
Post by In-Tech » Mon Mar 12, 2018 12:27 am
Totally agree with ya Bill, I was just asked to look at a broken(not completely, just hurt) combo and the first thing I saw was moly FILLED ring and not plasma, it did have a tapered second, I'd still use a napier second any day I could find one within reason.
I mean seriously, you have a LSX block NA making 600 fwhp and you're hurting stuff in 2000 miles? All I could say was, bad parts and bad tune(was that extra 10 hp worth the bad tune)? :(
When you don't have control over the entire engine, and you never do, you have to watch the breathers and that little thing in the front called a belt tensioner. When things are good, nothing comes out of the breather for that split second and the tensioner is steady. That tensioner is rattling for a reason. :wink:
Good oil control in regards to the combustion chamber is a huge thing.
-Carl
gnicholson
Post by gnicholson » Mon Mar 12, 2018 1:43 pm
Thanks for the replys. Thinner rings arent enough improvement to justify buying new pistons are they?
Post by MadBill » Mon Mar 12, 2018 1:54 pm
No.
Here's a typical test. Going from 5/64" to 1.2 mm was worth ~ 8 HP @ 6,000 on a 450 HP 350. Worth considering only if you're already buying new pistons. https://www.youtube.com/watch?v=-29IWc-zrv8
Casper393W
Post by Casper393W » Mon Mar 12, 2018 5:26 pm
On a street type build why would one look to give up durability for just a few hp.
Andy
gnicholson
Post by gnicholson » Mon Mar 12, 2018 7:58 pm
Okay I called total seal and ordered a steel top ring Napier second ring and a 15 pound Oil ring. The bore size on this is 4.185 thanks for all the help
user-17438
Post by user-17438 » Mon Mar 12, 2018 11:07 pm
It all depends on how round and straight the bores are. You could run TS Gold rings on the street.
engineguyBill
Post by engineguyBill » Tue Mar 13, 2018 1:25 pm
Excellent choice.
Bill
DCal
Post by DCal » Tue Mar 13, 2018 1:39 pm
In your first post you said the pistons were 4.200 Diamonds, do you mean just the oil ring expanders are for 4.185?
gnicholson
Post by gnicholson » Tue Mar 13, 2018 3:09 pm
Its actually 4.185 not 4.2. I was going from memory and my memory aint what it used to be.
