fabrication question
Belgian1979
Post by Belgian1979 » Sat Mar 10, 2018 2:11 pm
I need to construct an air bypass line for intake runners. I would like to be able to restrict the airflow if needed. What would be the best way to tackle this ?
PS : I don't have a mill nor a lathe.
ProPower engines
Re: fabrication question
Post by ProPower engines » Sat Mar 10, 2018 2:14 pm
What is the purpose of this bypass??
Post by MadBill » Sat Mar 10, 2018 4:12 pm
You're a little short on detail but if for example you were talking say a 3/16" neoprene hose to each runner, you could press in brass Allen head set screws drilled to the desired orifice size. A box of 50 is only a few bucks from McMaster Carr or the like and would give lots of scope for going too big and starting over. If you're talking one big hose, you could just drill a metal or plastic slug of the right diameter, either pressed or threaded in.
Belgian1979
Post by Belgian1979 » Sun Mar 11, 2018 3:53 am
iac air to individual runners that I need to get balanced. The full details would mean a very very long explanation....
Belgian1979
Post by Belgian1979 » Sun Mar 11, 2018 3:54 am
That looks like something I could work with. However I'm dealing with an alu line which is fixed into the runner. Need to give this another thought.
Thanks Bill.
grandsport51
Post by grandsport51 » Sun Mar 11, 2018 4:55 am
How about needle valve manifold for aquarium co2 systems
http://www.aquacave.com/aquarium-co2-su ... alves.html
LIGHT 'EM UP
user-23911
Post by user-23911 » Sun Mar 11, 2018 6:35 am
Dump the ITBs and use a proper manifold with plenum.
mk e
Post by mk e » Sun Mar 11, 2018 8:26 am
The easiest would be don't bother then adjust the throttle plates to balance it. If you set the unloaded warm idle using the throttle not the is the whole system will be much less sensitive and your off idle throttle will be easier to manage
A version Bills suggestion is the other path. The fanciest version is to use needle valves, they make pipe thread on 1 end that you could screw into the little plenum. The very cheapest version is solder the fittings you have shut and drill to size.
Mark
Mechanical Engineer
bill jones
Post by bill jones » Sun Mar 11, 2018 10:12 am
---I did the same thing on a Crower fuel injection---
---I found 8 small needle valves with 1/4" tube spouts and 1/8NPT male fitting ends---just use some short pieces of push-on hose.
---I don't remember where the valves came from.
englertracing
Post by englertracing » Sun Mar 11, 2018 11:27 am
So step 1 is to get a mill and a lathe.
Leftcoaster
Post by Leftcoaster » Sun Mar 11, 2018 12:44 pm
Your local plumbing or hardware store should have small brass bleed screws very similar to those posted by Bill Jones
They're used to vent air bubbles out of the radiators in countless large buildings such as libraries and hotels
peejay
Post by peejay » Sun Mar 11, 2018 12:44 pm
It would be far easier to use an IAC motor that opened the throttle directly, for various reasons related to the strangeness of IR setups. 1980s Cadillacs with the 4.1/4.5/4.9l engine used a stepper motor throttle stop for idle control that would serve you well.
peejay
Post by peejay » Sun Mar 11, 2018 12:46 pm
Plenum manifold engines drive like shit. Poor throttle response and awful midrange.
Belgian1979
Post by Belgian1979 » Sun Mar 11, 2018 2:27 pm
This certainly is a possibility, but I never found a stepper motor powerfull enough to work against the springs and such. Do you have a part number ?
Belgian1979
Post by Belgian1979 » Sun Mar 11, 2018 2:28 pm
Bill,
Interestingly enough I was thinking of doing something similar. Did the needles work in a 1/4" hole. Most needles I see are very tiny and wouldn't allow enough airflow past them.
