Valve Seat Angles and Flow Area
Stan Weiss
Post by Stan Weiss » Tue Mar 06, 2018 10:45 am
I use a much different method for calculating seat area based on seat angle and seat width then what was shown before. This paper has a 3 step method which is very close to what I use to calculate the overall flow area which at most lifts is not the curtain area..
Have had this for sometime and have no link.
INTAKE_PORT_FLOW_STUDY_ON_VARIOUS_CYLINDER_HEAD_USING_FLOWBENCH.pdf
Stan
RevTheory
Re: Valve Seat Angles and Flow Area
Post by RevTheory » Tue Mar 06, 2018 10:52 am
Dumb question, Stan: what is "SAE"?
user-9274568
Post by user-9274568 » Tue Mar 06, 2018 11:01 am
Stan, I would need to ask Darin how that was written. This is a spreadsheet I got from him many years ago.
n2xlr8n
Post by n2xlr8n » Tue Mar 06, 2018 11:38 am
I'm going to assume it's the Society of Automotive Engineers' formula for discharge coefficient until Stan says otherwise.
Stan Weiss
Post by Stan Weiss » Tue Mar 06, 2018 11:42 am
That is correct.
Stan
pcnsd
Post by pcnsd » Tue Mar 06, 2018 11:39 pm
Stan,
Do you have a link to the referenced pdf file?
- Paul
pastry_chef
Post by pastry_chef » Tue Mar 06, 2018 11:57 pm
Stan,
http://umpir.ump.edu.my/169/1/INTAKE_PO ... WBENCH.pdf
Mike R
pcnsd
Post by pcnsd » Wed Mar 07, 2018 12:44 am
Stan,
Thank you for the link. After a quick scan, I will confess that I had hoped for more, still I will pull the equations and logic and see if they are better than what I have.
- Paul
Stan Weiss
Post by Stan Weiss » Wed Mar 07, 2018 10:47 am
Paul,
What I had posted was the calculated MCSA @ each lift point. Using that and its flow I calculated SAE CD and velocity I was only referencing pages 24, 25, 26 of that PDF as a way to calculate the MCSA.
If what you are using is not proprietary. Why don't you post it up so we can have a look and see if it is better or not?
Stan
user-9274568
Post by user-9274568 » Wed Mar 07, 2018 10:54 am
Here is something else that is very beneficial in flow testing. CSA screen based off pitot readings.
Rick360
Post by Rick360 » Wed Mar 07, 2018 2:11 pm
Neither of the spreadsheets in Stan's post are correct in calculating the actual curtain area for different valve seat angles.
There are not enough inputs to calculate it correctly.
Rick
CGT
Post by CGT » Wed Mar 07, 2018 2:29 pm
Rick
Yeah, I noticed that...not the math but the results between the valve angles(differences in window area) are nowhere near what I'm used to seeing using Ricks proprietary software. Therefore the DC figures are junk too.
"How or Y do you think I get all this $hit, I read all of you all builds and desktop dyno them with all the correct info and I've got your build."
Stan Weiss
Post by Stan Weiss » Wed Mar 07, 2018 3:02 pm
Stan
Reading Comprehension :)
The formulas I quoted came from
"A report is submitted in partial fulfillment of the requirements for the award of the degree of Bachelor of Mechanical Engineering with Automotive Engineering"
"The instantaneous valve flow area depends on valve lift and the geometric details of the valve head, seat and stem. There are 3 separates stages to the flow area developments valve lift increases.
Stan
Rick360
Post by Rick360 » Wed Mar 07, 2018 3:28 pm
Stan
Stan
Yeah, I saw it and it appears to be the same or similar to the Vizard spreadsheet you posted which is incomplete. Does not have ALL of the variables needed to calculate it fully, but it is simpler. It'd work fine IF the valve is shaped like the one in the picture in that paper, but is incorrect for any type of race valve that I have ever seen or used.
Rick
digger
Post by digger » Wed Mar 07, 2018 4:15 pm
There is no way to simple describe it. If you look at cfd results the chamber comes into it as well. Do best you can do is an approximation
