Valve spring choice has more to do with what lobe and rocker ratio you are using. I have spun 7800rpm with oem hydraulic rollers without problem using hardly any spring pressure. And I have spun 9000rpm using almost the same spring pressures with a solid roller. You need to talk to the cam grinder, work with him on your valve weights and rocker ratio.Dragsinger wrote: ↑Fri Feb 23, 2018 6:33 pm Help me begin my education of the LS engines mechanical roller valve train.
Questions:
*considering the LS3/L92 rectangular-port head.What is required for valve springs and rockers to accommodate adjustable rockers and .750" range lift?
*This engine will spin in the 7800 RPM range and make around 700 horse. It will be carburated with a powerglide, dedicated, trailered, serious drag race package.
I am not interested in a non-adjustable, hydraulic valve train.
How dedicated are you? Change valve springs every 10 passes kind of guy? Is .750 the maximum lift for a reason? Too many variables. Call LSM, Mike Jones, Bullet. And see what they say. If I tell you from my past experience and you chose a different component from why worked for me could be catastrophic for you.
