Cylinder head I.D.?
88bluestar
Cylinder head I.D.?
Post by 88bluestar »
Cast iron small block chevy head,
vertical number is 080207, and horizontal number is 10445?
prairiehotrodder
Re: Cylinder head I.D.?
Post by prairiehotrodder »
whats the cast-in number under the valve cover ?
rfast racing
Post by rfast racing »
080207 is probably date it was worked on and 10445 is probably work order #
mag2555
Post by mag2555 »
It's a Vortec head, either a 906, or 062 casting!
rfoll
Post by rfoll »
mag2555 wrote: Fri Feb 23, 2018 8:15 am It's a Vortec head, either a 906, or 062 casting!
That's what I thought too, but I don't see the saw tooth marks they usually have.
Keith Morganstein
Post by Keith Morganstein »
88bluestar wrote: Thu Feb 22, 2018 4:34 pm Cast iron small block chevy head,
That looks like a mid 1990's 305 head. 12558059
rfoll
Post by rfoll »
The casting numbers under the valve cover will tell the story, date code and application...305 or 350
88bluestar
found the number, they are large port bowtie vortec heads, sadly i'd prefer the smaller vortec bowtie ones for my class rules but its what came with the car.
midnightbluS10
Post by midnightbluS10 »
It never crossed your mind to look up that number before someone instructed you to? More times than not, you'll find more info about cast in numbers than you will numbers that have been stamped on afterwards. Those could be stamped on by anyone, anywhere, at any time.
Are you not familiar with GM castings? Or how to identify them?
JC -
