Best Bang-For-Your-Buck Crank & Rods?
So what is everyone's best bang-for-the-buck Crank & Rods for a SBC? I was about to order a 4340 SBC crank and rod set from Scat and I'd thought I'd check out here to see if there's something better that won't break the bank.
Joe Facciano
Re: Best Bang-For-Your-Buck Crank & Rods?
What HP engine are you talking about? I've had good luck with scats lightweight cast cranks at 450-500hp level on my own personal engine and one I built for my step brother. Mine has 9 years of bracket racing on it, still passes a mag test and mics good.
I use a lot of Scat cranks and rods. Prices I consider good and the care in machining is evident.
Monty Frerichs
B&M Machine
B&M Machine
Made 1400 hp on callies compstar crank and h beams. When i bought them they were like 200$ cheaper then i believe. Back in 08-09
But they are good
But they are good
Depends on what the engine will be used for. Street/Strip/Bracket racer, Scat crank and rods are best value, in my opinion.
Bill
SAE Member (30 years)
