Cam duration
Re: Cam duration
so what we are saying is, that you have to have the heads/intake/carb to support the increased duration of the cam to actually see an increase in useable rpm.
Re: Cam duration
So the heads here and intake are not enough? Im thinking the cam is short. Thats why im asking.
Re: Cam duration
I didn't say it wouldn't be faster if it made more power.
You asked about cam vs rpm and posted a dyno sheet. I was just pointing out the peak TQ to peak HP rpm spread seemed narrow from the good engines I've seen, maybe a sign of something not matched well.
Re: Cam duration
im not saying that, but if you want more rpm and add duration expecting to see an increase in rpm, the heads and intake could be the limiting factor.
Re: Cam duration
Like short on duration? What would u change. Car weighs in at 3700. I think the heads and intake are lots ahead of cam.
Re: Cam duration
1200-1500 rpm is normal on most stuff I've seen.swampbuggy wrote: ↑Thu Feb 22, 2018 9:53 pm Randy-----what would you consider an excellent spread ??? Mark H.
Our emc engine was 1600-1700 rpm. I've seen 1800 rpm, but being too far apart is probably a sign something isn't matched well, just as much as not enough spread is.
But the application would dictate if a big spread is desirable.
Re: Cam duration
. If you take peak hp which varies by 2hp from 6600-6900 you have 1300 spread roughly. Duration will move peak up for sure. Will we see gains? Thats the big question i guess.
Re: Cam duration
I would like to see another .050"+ net lift and 5/8* on the intake.
I dont know the .200" figure on your cam , do you know Steve?
Can you lash the intake tight for a run to try and get a rough idea of what it wants.
Re: Cam duration
Craig thanks. Thats what im wondering? I was hoping to work around lift as clearance tight now. Duration may be tough to get even. But just wondering. Cam card above.
Re: Cam duration
Ah bugger!
Are your clearance problems head related- retainer/guide/seal etc at full lift OR piston/valve clearance?
Contact Crane and get the .200" duration or someone here will have it im sure.
I dont see duration alone giving the best result.
