350 Pontiac undersized harmonic balancer
I just finished a Pontiac 350 build and crankshaft is aftermarket. The crank snout diameter measuring 1.3710” the balancer bore is 1.3745. Does any one make a undersized balancer for Pontiac, or what have any of you guys done in past to resolve an issue like this. Thanks for everyone’s time.
Re: 350 Pontiac undersized harmonic balance
What balancer are you using??
I have done several stroker builds but the last one I had issues with even getting a new balancer.
I had to send the OE balancer to be rebuilt as Power-Bond was out of the better balancers and they were about 4 months back ordered at this time last year.
But I did find that there are several different styles and if you are using the stock pointer you may have issues if the crank is undersized as the balancers are a very tight fit and need honing most times to get the correct press fit but that is an item that needs to be checked prior to any work proceeding.
The only recourse you may have is to bore and sleeve the balancer you have to correct the press fit if the crank is sized that far off.I have done this on many balancers that the crank was worn in the balancer mounting area.
According to Professional Products http://www.crankshaftcoalition.com/wiki ... _Instr.pdf your snout is three thous undersize and the damper is five tenths beyond the upper limit. They list the crank at 1.374" to 1.3735" and the damper ID at 1.373" to 1.374".
It would be just moving the issue down the road, but Loctite could be an option. Retaining compound 638 is good for ~ 4,000# shear strength, so a damper bore of 1.374" x say 2" would be over 30,000#. Something rather weaker would likely suffice...
Re: 350 Pontiac undersized harmonic balancer
Bill you right on the numbers, I’am getting a knocking noise at idle I believe it is do to balancer movement.
looks like a bad crank,I have done tons of pontiacs and have never had a loose one.One of the aftermarket balancers is tight.On that one I need a puller to remove.FWIW,Tom
Long ago before aftermarket dampeners existed for Pontiacs my friend bracket raced a ventura. One odd thing that I noticed was neither engine he had for it required a puller to remove the dampener. They weren't sloppy loose but with a bit of work you could pull them off by hand.
The torsional forces are very high. I have often seen it written that a heavy press fit is necessary to prevent fretting in most apps and that the key should be regarded as just an alignment device. I guess Pontiac and others didn't read the same books...
Bill,
The dampener bolt is torqued to 160 ft/lbs [ minimum ], factory spec. If properly torqued, there is no problem with the design.
Pontiac V8 Balancers are not, nor never have been the press fit type!
Glad I slipped the '...most apps...' escape clause into my post!
I have found that all the Pontiac's I ever did were all slip fit. They were 400 cubic inch GTO motors 68-70's
Romac says they started making undersized balancers as catalogue items for some strokers 'cause the crank snouts were so often undersized. Might call one of their U.S. dealers & get the current skinny. Maybe your engine is one they have a part for. Mine has been on the motor (not a Poncho) for 15 yrs and I have no complaints. Mechanically restrained and rebuildable, too.
