Race tek pistons
Re: Race tek pistons
Mark,
If you don't mind me asking, just what did you end up doing?
Just wondering and I hope everything works out for you.
I read where you finally got moved.
Yeah, in the ring industry we refer to pistons as "ring holders" . . . . . . .Mark O'Neal wrote: ↑Fri Feb 23, 2018 6:21 pm
All of them have things I like, all of them have things I don't. All of them keep the rings from falling into the oil pan.
Bill
SAE Member (30 years)
The beautiful suburb of San Tan Valley, AZ...because two of my son's live here.
I've been here just long enough to wonder why.
I was getting the in three or four days for a while there. If y'all would stop bugging them, I still would be.KnightEngines wrote: ↑Tue Feb 20, 2018 10:52 pm Just an aside - last set I got arrived in 12 days, & I'm in Australia!
They must had had them done within a few days of ordering them for that to happen.
I have 30 year old Arias pistons in my current Ford 331. Pin is in the ring groove and doesn't use oil . LOLMark O'Neal wrote: ↑Fri Feb 23, 2018 6:21 pm I use mine...and Ross, and CP, and JE, and Wiseco, and Diamond, and Racetec. Whichever one works with the application and fits the customers budget is fine with me.
Racetec is a good part for a good price. What more can you ask for?
Having said that Tim at Racetec still has a set of Probe's in his SB Ford......
- af2
Without calling Race tec and bugging them. On a blown Alcohol small Chevy I am putting together will they do a thick crown and Dyke top ring on a 4.130 bore?
GURU is only a name.
Yes they will. I had thicker crowns added to this 438. Think i ended up near .405 thick.
Here is a piston I had Racetec make me. I dealt with Tim there and he was great to deal with. Gave them all the specs I could and an old Wiseco and told them to make me one "better". They absolutely did.
-Bob
Work or art really!! Kind to hate to put in!!that crown looks at least .400 on outside edge.
I just said that because I was talking to Tim and know that Jeremy was looking a tht e thread.piston guy wrote: ↑Mon Feb 26, 2018 2:47 pmI have 30 year old Arias pistons in my current Ford 331. Pin is in the ring groove and doesn't use oil . LOLMark O'Neal wrote: ↑Fri Feb 23, 2018 6:21 pm I use mine...and Ross, and CP, and JE, and Wiseco, and Diamond, and Racetec. Whichever one works with the application and fits the customers budget is fine with me.
I don't see any reason why not......although I haven't cut a Dykes ring groove since I can remember when.
Adam ,
That's not a problem as long as the compression height allows it. NOT possible on a 4" stroke 6" rod deal, no room. Not possible on a 3.75" x6" either. It would need a 1.200 C/H or more to work "for me" . Call and bug Racetec anytime , help is what it's all about.
- af2
Thank you very much... It is looking like a 3.75" and a 5.7 rod then. Heading to Bakersfield this weekend to spectate and dodge rain. We are supposed to dumped on up here.
