With all disrespect, there is a lot of teeth gritting to many when you post Chad. Because of the way it comes off as. You are the only one fat can do it. And there is only one way. You discredited steel seats, then counterdicked yourself saying they work. What is it. Why can one guy use them and' it be wrong, but you use it and it's right?
And yes you do come off VERY arrogant.
Valve seat angles
Re: Valve seat angles
With "all disrespect"??
You ever hear of the golden rule?
Get what you give.
Get what you give.
Maybe it's just the way you take it. I don't think I'm the only one that can do it. I have more respect for Larry than most, I wonder if he thinks that?Headguy wrote: ↑Mon Mar 05, 2018 11:31 pm With all disrespect, there is a lot of teeth gritting to many when you post Chad. Because of the way it comes off as. You are the only one fat can do it. And there is only one way. You discredited steel seats, then counterdicked yourself saying they work. What is it. Why can one guy use them and' it be wrong, but you use it and it's right?
Show me what I said about steel seats. No idea what your talking about.
I'd show you more respect if you didn't call me names or post your name, or tell us who you are. Understand that? Probably not.
And who are you speaking for when you say lot of teeth grinding? Please speak up!
All of this with disrespect..
Sometimes its hard to tell the difference from pride and arrogance with text. One guy will read something one way, and some another. Chad posts pictures and results, I'm sure nobody wants to post up a turd of a cylinder head they ported, why should he be any different. I thank anyone who gives honest advice on here and contributes to posts. I try to learn all I can from here, and put in my 2 cents when I feel I can. I'm a hobbyist, but I am doing it. A vast majority of people I race with don't assemble their own engines let alone cut valve seats and set up valve springs, and port their own stuff.
Dude! Go Away!Headguy wrote: ↑Mon Mar 05, 2018 11:31 pm With all disrespect, there is a lot of teeth gritting to many when you post Chad. Because of the way it comes off as. You are the only one fat can do it. And there is only one way. You discredited steel seats, then counterdicked yourself saying they work. What is it. Why can one guy use them and' it be wrong, but you use it and it's right?
For those keeping score at home, gmrocket and headguy are the same person. Just click on Headguys posts!
Maybe a mod should check the IP.
Could be a screw up on the forums quotes, I have had them put other quotes in mine or name others that I didn't quote but either way they need to go away if they are not going to at least argue actual tech in relation to the thread.
