SBC stock valve spring installed height??
What is it for my old -462, (1.94"/1.50" dia.), medium valve stock heads??
1.70", 1.75", or 1.80"???
I am having trouble finding this out is why I ask.. If it is in HP's old book, "How to Hotrod SBC's", I missed it....
Thanks,
Thanks,
Re: SBC stock valve spring installed height??
my 1967 462 heads with stock gm 194 valves are at 1.7-1.72 with no shims
Long Island, NY
Thanks Kbails,
I'm finding 1.70", 1.75", 1.78", and 1.80", so go figure?
I figured 1.70 plus a skosh so I am fine.
72 truck and passenger car shop manual pdf to download for free.
http://67-72chevytrucks.com/vboard/show ... ?p=5781194
Not sure if those are the right heads, but a solid lifter lifter 350 //might// be similar.
1.719 =/- .031
1.719 =/- .031
Elgin Performance Valve Springs PN RV-1943X for SB Chevy - Stock Diameter - 125 lb. @ 1.750", 325 lb. @ 1.200"
It say's 125 pounds @ 1.75" installed height.
I guess what I am asking is, will I be OK at 1.70" installed height or should I get a set of .050" taller keepers?
As long as you have enough retainer to guide / seal clearance and no coil bind, you are good.
Hi pdq67,
125# seat pressure. That does NOT sound like a "SBC stock valve spring".
Maybe along the lines of 3927142 for use with the early off-road cam for real Trans Am use?
The free length is important to, specially if the pressure ( force, really ) open and closed is not confirmed.
I call the old -142 valve spring, the Z-28 spring even though it was used with the old -140 solid cam.
Thanks Dan, I will check free height when I install them then check everything else.
PS., they are supposedly good to .600" lift...
Iirc. The 943x are the z-28 spring.
1943x are .100 longer. Used several sets of those a million years ago on dirt track sft deals. Work good but would always break the dampener, but were cheap so just remove and replace.
- midnightbluS10
Also try here. They have all kinds of stuff. Original shop manuals. Brochures. All kinds of literature on all kinds of vehicles and parts.Dan Timberlake wrote: ↑Sun Feb 18, 2018 11:37 am 72 truck and passenger car shop manual pdf to download for free.
1.719 =/- .031
http://oldcarmanualproject.com http://www.oldcarbrochures.com and http://www.oldirononline.com
JC -
Thanks midnight,
I am going to use them with .500" solid flat-tappet lifter cam.
I'm shooting for about 125 to 130 or so seat and 325 or so over the nose. If I have to, I will use my .050" taller keepers? I know these springs aren't all that fancy , but I figure that they should go to 8,000 rpm. For how many times, I don't know?
I always pull springs with flat dampeners apart and de-burr the dampeners before I run them,they can be a bit raggedy-ass straight out of the package. Tedious? Well yes...so is changing valve springs with broken dampeners...
