Best fuel?
88bluestar
Best fuel?
Post by 88bluestar »
Best fuel for 9.5:1 360 cid Engine? Oval track dirt track racing. 180-190cc runner head, victor jr intake, 750 holley, headers
cgarb
Re: Best fuel?
Post by cgarb »
nitromethane hands down...if you can keep the rods in it.
induction apprentice
Re: Best fuel?
Post by induction apprentice »
:lol:
GARY C
Re: Best fuel?
Post by GARY C »
I would start with a 50/50 of 110 and 87 pump gas and tune from there. you may only need 1/4 or 2/3 gallon mix for 5 gallons to be safe.
ZIGGY
Re: Best fuel?
Post by ZIGGY »
Best performance - an oxygenated race fuel designed for lower compression engines.
Probably not best bucks vs. power.
Old as Dirt
Re: Best fuel?
Post by Old as Dirt »
100LL Avgas should be more than enough to satisfy your engines compression needs..
David Redszus
Re: Best fuel?
Post by David Redszus »
After twenty five years of fuel blending and testing, I have concluded the following:
Selecting the best fuel is much like selecting the best woman. It all depends on purpose and use.
For short, circle track racing, throttle response is much more important than horsepower. The data
indicates very many racers never get to full throttle and most only when part way down the straight.
Never use pump gas. It has absolutely no consistency (by design); it will vary from batch to batch, day to
day and month to month.
For the above application I would blend an 110 octane (115/105) with a low temperature distillation
curve, except for hot summer weather. For best results, this leaded fuel would contain a non-alcoholic
oxygenate (ether). It must be kept very fresh, out of sunlight, heat and air.
Test the fuel before use to ensure that you have what you think you have. Do not trust the comments of
fuel marketers or other racers. Collect your own data and study it. Tune to changes in weather.
Truckedup
Re: Best fuel?
Post by Truckedup »
VP fuel website has the specs on their dozens of fuels..... Reid vapor pressure and 90C evaporation are important....There is more to gas than octane...
user-17438
Re: Best fuel?
Post by user-17438 »
ZIGGY wrote: Fri Feb 16, 2018 9:50 am Best performance - an oxygenated race fuel designed for lower compression engines.
Like Propylene oxide?
ZIGGY
Re: Best fuel?
Post by ZIGGY »
MTENGINES wrote: Fri Feb 16, 2018 4:29 pm Like Propylene oxide?
Hell no! (I am acquainted with it [-o< )
ZIGGY
Re: Best fuel?
Post by ZIGGY »
ZIGGY wrote: Fri Feb 16, 2018 6:49 pm
Hell no! (I am acquainted with it [-o< ) :lol:
Geoff2
Re: Best fuel?
Post by Geoff2 »
David R,
And the women are probably easier to find....
