INTAKE PORT PROBING WITH FLOW BALLS
user-9274568
Re: INTAKE PORT PROBING WITH FLOW BALLS
Post by user-9274568 » Sat Feb 17, 2018 11:44 pm
What does a spot flowing backwards look like with a pitot?
jed
Post by jed » Sun Feb 18, 2018 9:15 am
I know Jole Dubose swore by using the flow balls.
Post by MadBill » Sun Feb 18, 2018 10:05 pm
Should show negative dynamic pressure I'd guess; probably erratic due to turbulence induced by the upstream arm.
pcnsd
Post by pcnsd » Sun Feb 18, 2018 11:02 pm
Wouldn't that be easier to see with a string on a stick or even a bunch of strings on a stick? I suppose if you felt the need to quantify it, you could measure with the pitot, but why?... What you want to do is make it go away.
- Paul
GARY C
Post by GARY C » Mon Feb 19, 2018 1:12 am
The flow ball kit I got came with flags also, the flag/string gives you direction, the proper size flow-ball gives you an idea of where to fill and how much is needed... at least in theory. :)
It seems more times than not the apparatus you stick in the port effects the measurement enough that it can not be duplicated without the apparatus in the port.
