INTAKE PORT PROBING WITH FLOW BALLS
HIGHOCTAIN2000
Post by HIGHOCTAIN2000 »
WHEN YOU PROB AN INTAKE PORT WITH FLOW BALLS I UNDER STAND THAT WHEN FLOW IS REDUCED IT IS A BUSY AREA, I UNDER STAND THAT WHEN TRERE IS AN AREA WITH NO CHANGE IT IS A DEAD AREA, WHAT DOES IT MEAN WHEN YOU PROB AN AREA AND YOU GAIN FLOW.
Amilcar
Re: INTAKE PORT PROBING WITH FLOW BALLS
Post by Amilcar »
The flow is reattaching after the ball. Which wasn`t before , caused by shape/too high velocity or both.
Newold1
Post by Newold1 »
When probing the air flow in a port I think it's best done with a pitot tube. Not even sure what flowz balls are?
GARY C
Post by GARY C »
mag2555
Post by mag2555 »
Probing with the proper Pitot tube puts you light years ahead of finding out where the air mas is moving thru a port then flow balling a port if you want my 2 cents worth!
Carnut1
Post by Carnut1 »
Flowballs really help if teamed up with Pitot airspeeds.
mag2555
Post by mag2555 »
If yòu in a real serious development session on a head and you have one you can sacrifice for the cause then cutting it up and drilling it with long bits to press or glue in 3/32" tubes around the valve bowl and taking pressure readings off of each tube at .050" valve lift intervals will provide a very clear picture of where the air mass is going a this in turn will provide you with insite as to how well your port shape is making use of your valve bowl Throat and valve size.
You want to use thick wall tubing like Aluminum so you can round over the tubing nose that sticks out into the valve bowl wall.
This fully beats out flow Ball useage and if you tie it in with Pitot tube readings in the runner is very informative to say the least!
Amilcar
Post by Amilcar »
Blowing thru the intake manifold side of the port, having the cylinder bore adapter attached to head, is a very good alternative to do this.
Helps whatever the region of valve you want to check, as well as it´s a prototype head or not.
user-9274568
Post by user-9274568 »
I love my pitot tube, but the flow balls are 1a to me.
4vpc
Post by 4vpc »
cspeier wrote: Fri Feb 16, 2018 9:04 am I love my pitot tube, but the flow balls are 1a to me.
What does that mean?
jed
Post by jed »
4vpc wrote: Sat Feb 17, 2018 3:40 am
I don't know what 1a means eather???
4vpc
Post by 4vpc »
jed wrote: Sat Feb 17, 2018 9:07 am
I don't know what eather means either!???
user-9274568
It means they both are #1 to me. The flow balls are 1a and the pitot 1b if I had to rank them.
All a flow bench is for is the lifeblood for visual aides.
4vpc
Post by 4vpc »
cspeier wrote: Sat Feb 17, 2018 9:55 am It means they both are #1 to me. The flow balls are 1a and the pitot 1b if I had to rank them.
Yes I agree. How do you utilise them, what are you looking for and how do you interpret it? I read somewhere a long time ago that they can be used to re-attach the flow?
gnash
Post by gnash »
I find an S-type velocity probe works best for me.
With a velocity probe, you can find spots that may be flowing backwards, or eddies.
