How far can you deviate on piston weight before needing to rebalance?
travis
Post by travis » Wed Feb 14, 2018 11:29 pm
For a purely street/utility use 351w that was balanced with a set of 790 gram pistons/pins, would you rebalance after to going to a 21 gram lighter piston and pin? This thing will rarely, if ever, see 5000 rpms. I am concerned about long term durability and having a smooth running engine
rustbucket79
Re: How far can you deviate on piston weight before needing to rebalance?
Post by rustbucket79 » Thu Feb 15, 2018 12:13 am
You'll never notice the difference but if you can afford, especially if you need to replace a flex plate or resurface your flywheel or replace your harmonic you may as well balance. Much better than wishing after the fact. #-o
Ericnova
Post by Ericnova » Thu Feb 15, 2018 12:14 am
Being lighter like that wouldn't even make me blink. Run it.
Post by MadBill » Thu Feb 15, 2018 3:03 pm
Lots of engines are deliberately 'overbalanced' by more than that.
