Theoretical question about air flow...
Krooser
Post by Krooser » Wed Feb 14, 2018 11:25 pm
Okay... I was visiting my old friend Al who does excellent carb work... he couldn't answer this so you guys have a shot...
If I spread Vick's VapoRub all over my air filter will my engine breathe better?
Alcohol was NOT involved...
superpursuit
Re: Theoretical question about air flow...
Post by superpursuit » Wed Feb 14, 2018 11:29 pm
Only if it has the sniffles. LoL. :D :lol:
lefty o
Post by lefty o » Thu Feb 15, 2018 12:24 am
the tail pipe will burn your nose!
Tuner
Post by Tuner » Thu Feb 15, 2018 1:34 am
Are you troubled with post-nozzle drip? If you have occasional combustion reflux perhaps a dab of Vics and advancing the timing a bit would help.
Circlotron
Post by Circlotron » Thu Feb 15, 2018 2:58 am
The petroleum jelly portion might upset the AFR.
user-23911
Post by user-23911 » Thu Feb 15, 2018 3:05 am
If it's a paper filter, it'll probably give a bit of restriction until it pretty much all gets sucked into the engine, then it'll burn and the filter won't be quite so restrictive.
Who's going to give it a go?
levisnteeshirt
Post by levisnteeshirt » Thu Feb 15, 2018 11:00 pm
Perhaps to seal the filter to the base of the air cleaner , bacteria often hides in these areas and promotes infection
David Redszus
Post by David Redszus » Thu Feb 15, 2018 11:10 pm
Do you mean fuel infection or direct infection?
levisnteeshirt
Post by levisnteeshirt » Thu Feb 15, 2018 11:19 pm
Can be either , reversion can drive fuel to these areas and accelerate the spread of infection
cgarb
Post by cgarb » Thu Feb 15, 2018 11:50 pm
If the Vicks backs everything up, just give it 2 suppositories up the tailpipes...lol. That will clean it out.
