Header size for 430 inch sbc
gnicholson
Post by gnicholson » Mon Feb 12, 2018 3:02 pm
Im in the process of going back together with this 4.200 by 3.875 11 to one street sbc. It has 1.750 3 inch headers on it now with 3 inch exhaust all the way out the back. Its a 69 vette so the mufflers have to basically be where they are and 3 inch is about as big as i can go. My question is with the exhaust would it be worth going 1.875 by 3.5 headers? My guess is it would help a little over about 5500 rpm and probably not be worth it for a street car. It should make about 600 hp
lekid
Re: Header size for 430 inch sbc
Post by lekid » Mon Feb 12, 2018 4:13 pm
In my opinion, for torque, 1-3/4" into 3" is probably decent. For horsepower, the 1-7/8" into 3-1/2" will make more for sure!
What vehicle is that engine in?
gnicholson
Post by gnicholson » Mon Feb 12, 2018 4:16 pm
69 corvette tko 600 5 speed overdrive 373 gear
Newold1
Post by Newold1 » Mon Feb 12, 2018 4:38 pm
I think your finishing thought in your original post answered your own question quite nicely.
As a suggestion based on your transmission type, put the dollars into a nice set of 4:11 rear end gears instead of headers and in street driving you will see more performance in the "butt" dyno and be much happier!
gnicholson
Post by gnicholson » Tue Feb 13, 2018 3:22 pm
Someone with pipe max. What are the ideal exhaust dimensions for this thing?
af2
Post by af2 » Tue Feb 13, 2018 5:09 pm
Put mufflers on and throw all else out the window unless you have 1.250" headers.
GURU is only a name.
af2
Post by af2 » Tue Feb 13, 2018 5:12 pm
Buy the program like we did.. Larry spent way too much time for someone to borrow it.
af2
Post by af2 » Tue Feb 13, 2018 5:16 pm
And you have not even got close on the amount of info Pipe Max needs to calculate your set up.
gnicholson
Post by gnicholson » Tue Feb 13, 2018 5:32 pm
Fair enough. I dont know have the program so i dont know exactly what info is needed. I can guess. I have seen other people ask the same question on here . I was just curious what dimentions would be optimal. Ive spent money on here i just havent bought that program yet but i will and ive had it on my mind for awhile to purchase
JoePorting
Post by JoePorting » Wed Feb 14, 2018 10:45 am
Big headers are overrated for performance and a big PITA to install and work around. I'd keep what you have.
Joe Facciano
