Distributor Housing to Intake Bore Clearance
hotrod1442
Post by hotrod1442 » Sun Feb 11, 2018 10:26 pm
Does anyone have a BBC intake manifold handy that can take a measurement of the distributor hole bore size?
The intake manifold that I'm working with (early Olds DRCE-1 cast intake), just has a oval shaped opening where the distributor enters the manifold. I'm machining a "puck" to fill in this area to accept the distributor shaft. I'd like to get the proper bore size/clearance while I have it setup in the mill.
Thanks, Dave
