Aluminum Rod material?
Truckedup
Re: Aluminum Rod material?
Post by Truckedup »
Many British motorcycles from the 1930's to they all went out of business in the 60-70's used forged aluminum rods, some with a steel cap. I believe it was called Duralumin....After all these years many including me don't trust them ...You measure the rod big end, if it's out of round by about .001" ,the rods are scrap, they cannot be resized. This is the only warning you'll get before the rod fails...
I use R&R aluminum rods in one of the race bikes. The other uses steel rods...
peejay
Post by peejay »
I believe Dural was a 2000 series alloy.
David Redszus
Post by David Redszus »
Given the choice, the rod material of choice would be titanium.
Ti far exceeds Al in every aspect: thermal expansion, thermal coefficient, tensile, elongation,and hot strength.
Al does have an advantage in density, 0.1 to 0.16, but both are far lower than steel.
autogear
Vendor
Post by autogear »
peejay wrote: Tue Feb 13, 2018 6:46 am I believe Dural was a 2000 series alloy.
You are correct. Closest modern alloy would be 2014 or 2024 I believe. Most notably used in Zeppelins (Hindenburg and others) after its invention in the early 1900s
Fireonthemountain
Post by Fireonthemountain »
In the next few years there probably will be the plastic/graphene rods. Lighter than just plastic rods alone, and graphene is harder than diamonds and 100 times stronger than steel, while being lighter than air, and transferring heat 12 times better than copper. And thats just the tip of that iceberg. :D
Racing68
Post by Racing68 »
Graphene rods would be nice but if the set costs $75,000 i doubt there would not be many buyers for those.
Morgo
Post by Morgo »
graphene? just study this page and be dizzy :shock:
https://www.sciencedirect.com/science/a ... 2115002084
"when uncomptent order unwilling to do unnecsessary the probablity of failure is high"
Momus
Post by Momus »
autogear wrote: Tue Feb 13, 2018 11:21 am
Dural/2024 was the highest strength alloy readily available to the Brit designers. Compared to 7075 at engine operating temperature it has similar uts but significantly less fatigue strength.
SchmidtMotorWorks
Vendor
Post by SchmidtMotorWorks »
Momus
Post by Momus »
SchmidtMotorWorks wrote: Tue Feb 13, 2018 10:23 pm Read this
https://www.google.com/patents/US6502480
Interesting. No vendors available for that material according to Mat Web. May be another experimental material that is good in compression but severely anistropic and or only produced in 10000 Kg mill quantities at many times the price of 7075.
The patent also expired 3 years ago due to non payment.
Fireonthemountain
Racing68 wrote: Tue Feb 13, 2018 1:29 pm Graphene rods would be nice but if the set costs $75,000 i doubt there would not be many buyers for those.
Graphene is costly when made a little at a time in a lab in a high dollar lab, but it is just the simplest carbon, and is found just about anywhere made from just about any source.Your lead pencil on school was actually graphene, on top of graphene, and so on. Many layers of it is called graphite. Strictly speaking graphene is only one layer thick, but 4 or 5 layers thick can have much of the same properties and that will be easier to produce.
There are already graphene tires, tennis rackets and more. Samsung has a new lithium battery, with a little graphene ball in it that will double or more the batteries life, and probably let it charge in a fraction of what they do now.
https://news.samsung.com/global/samsung ... ging-speed
A graphene plastic rods or crank might actually cost very little, in mass production.
Fireonthemountain
Morgo wrote: Tue Feb 13, 2018 3:55 pm graphene? just study this page and be dizzy :shock:
This is kind of along the same lines, or when they fed graphene to spiders.
https://newatlas.com/bionic-spider-silk-graphene/50908/
Now get this one, graphene riding across nano diamonds has virtually no friction.
Geoff2
Post by Geoff2 »
With the whittling down the weight of modern steel rods, while still maintaining strength, there seems little reason to me to risk using 'Kaboom' alum rods...
Mark O'Neal
Post by Mark O'Neal »
Momus wrote: Mon Feb 12, 2018 1:28 am They're almost always made from 7075 T6511. There are stronger grades ie Kaiser's 7068T6511 that are also used in higher $ applications.
Better strength at temp than 7075 though info is hard to come by.
Back when we used to make them we used 7075 and 7076 (for the SuperRods).
Childs and Albert used that "proprietary" material and Bob once told me what it was....but I forgot.
In-Tech
Vendor
Post by In-Tech »
Mark O'Neal wrote: Sat Feb 17, 2018 1:22 am
Mark, the brand "SuperRods"? If so, man I sure put those things to the test and they survived well, plenty of stories to tell about how good those rods were. :)
-Carl
