PipeMax question
no pressure
PipeMax question
Post by no pressure »
I searched and could not find an answer so......
Can someone please tell me What Z-factor Lift is?
and Intake time Area?
Thank you. attached pic
maxracesoftware
Vendor
Re: PipeMax question
Post by maxracesoftware »
no pressure wrote: Sat Feb 10, 2018 1:48 am I searched and could not find an answer so......
here's Help text from v4.00 :
Code: Select all
Intake Mach Z-Factor =  46.3116 % SOS          Exhaust Mach Z-Factor = 66.5537 % SOS
Note : Mach Z-Factor definition = PerCent %  of the Speed of Sound ( SOS ) at the Valve's Curtain Area
       Mach Z-Factor Valve Lift = calculated from Speed of Sound velocity thru Valve Curtain Areas
       System Flow Valve Lift   = calculated from Intake and Exhaust System Flow and Valve Diameters
       Port Flow Valve Lift     = calculated from Intake and Exhaust Port's Flow and Valve Diameters
       Curtain Flow Valve Lifts = calculated from Flow thru the Intake and Exhaust Valve Curtain Areas
       Time Area Valve Lifts    = calculated from User's Camshaft Durations, Curtain Areas, RPM Range
MaxRace Software
https://www.maxracesoftwares.com
no pressure
Thanks Larry, I'm still on version 3.98. How do I update?
dhidaka
Post by dhidaka »
Larry,
Assume you are limited in camshaft lift. If your intake or exhaust "time-area RPM" is much lower than intake or exhaust "system RPM" is that an indication that more camshaft duration would help HP/Torque? Say, 8000RPM vs 9200RPM. Also, what is a good target for intake and exhaust "Mach Z Factor"? My PipeMax says 0.628 intake Mach Z Factor. If that is too high, how does one slow it down?
maxracesoftware
Vendor
v4.00 to be released soon
dhidaka wrote: Sun Feb 11, 2018 5:37 pm Larry,
yes, if Intake or Exhaust Time-Area RPM Range is lower , it is an indication Cam Durations are too small
you can lower Mach ZFactor by installing a larger Valve and/or lower RPM Range
Time-Area RPM Range and Mach ZFactor, are just "BallPark" extra calculations
that lack additional needed inputs to make them trustworthy , so just look at them as "Trends" , and not as 100.0 % accurate
MaxRace Software
maxracesoftware
Vendor
no pressure wrote: Sat Feb 10, 2018 8:55 am Thanks Larry, I'm still on version 3.98. How do I update?
i just released PipeMax version 4.10
v4.10 is more accurate than previous release v4.00
v4.10 fixes small Bug in Weather HP Correction equations
v4.10 fixes small Bug in Camshaft recommended Specs
v4.10 adds additional Header Specs calculated Data results
v4.10 includes a couple more example Simulation Files
and corrects some typos in a few other included Simulation Files
Download and Install PipeMax v4.10 then Register to receive your UnLock Code
PipeMax v4.10 Download Link :
http://www.mediafire.com/file/h4p8dqvy8 ... 0.zip/file
( please read entire webpage about PipeMax at this Link )
http://www.maxracesoftwares.com/forum/v ... f=14&t=263
MaxRace Software
ou812
Post by ou812 »
maxracesoftware wrote: Sat Feb 10, 2018 3:48 am ]
Code: Select all
Is a lower Mach-Z factor better? Or?
Brian Hafliger
IMM Engine & Dyno
http://www.immengines.com
http://www.neilhepburn.com
maxracesoftware
Vendor
Brian Hafliger
IMM Engine & Dyno
these are good baseline Mach-Z factor's
Intake System Range = from around 40 to 50
Exhaust System Range = from around 50 to 60
on the Intake System Range , typically below 40, the Average CSA is too large = lower Port velocity FPS
above mid to high 50's , the Engine will have increasing Pumping losses and HP will fall off
MaxRace Software
ou812
Post by ou812 »
maxracesoftware wrote: Mon Nov 19, 2018 8:20 pm
Brian Hafliger
IMM Engine & Dyno
Thank you!
Brian Hafliger
IMM Engine & Dyno
