Holley jets
karter13
Holley jets
Post by karter13 » Tue Feb 06, 2018 7:27 pm
Hi. Trying to find the following Holley jets. Help needed, thanks. The Primary Main jet is: 22R-130-215. The Secondary jet is: 22R-130-550.
mag2555
Re: Holley jets
Post by mag2555 » Fri Feb 09, 2018 7:14 am
Have you called the Carb shop in Ca?
jmarkaudio
Re: Holley jets
Post by jmarkaudio » Sat Feb 10, 2018 1:42 pm
Where did you get those numbers from, and what carb are you working on?
Mark Whitener
____
turbo2256b
Re: Holley jets
Post by turbo2256b » Sat Feb 10, 2018 2:02 pm
thinking those are #S for a 5200 holley / webber if so look up jets for the webbers version
karter13
Re: Holley jets
Post by karter13 » Wed Feb 14, 2018 4:02 pm
Very old carb and numbers
Holley numbers direct from a Holley employee
450cfm economaster holley four barrel
List L-7456
Modal 4360
They are 1/4 - 32 pitch
Also will check into the Webber just in case
jmarkaudio
Re: Holley jets
Post by jmarkaudio » Thu Feb 15, 2018 9:42 am
Not sure if I ever tore into one of those, but if the threads are 1/4-32 they are the same as any gas Holley jet. Can you measure the passage size? Picture?
Mark Whitener
____
Kbails
Re: Holley jets
Post by Kbails » Thu Feb 15, 2018 10:24 am
HolleyJetSize.pdf
Long Island, NY
Kbails
Re: Holley jets
Post by Kbails » Thu Feb 15, 2018 10:26 am
this ^ may help you can get blanks and make whatever you need.
Long Island, NY
redliner
Re: Holley jets
Post by redliner » Thu Feb 15, 2018 10:49 am
List L-7456
Modal 4360
Those old Economasters are a good carb! I had one on a 355 I built for my 73 Blazer. I pulled my Stude with it and it performed flawlessly! Lotsa throttle response and still had a good top end! It seems to me it had progressive secondary linkage but no rear squirters, nary a bog nor stutter...
karter13
Re: Holley jets
Post by karter13 » Thu Feb 15, 2018 1:01 pm
Yes you are correct
As it is a old carb and thus I live in New Zealand the 215 and 550 main jets i cannot find on this side of the world.
I have emailed both the carb shop in ca and Daytona park but as yet no reply
So it's frustrating as I know what i need but cannot get it here and no contact back from the states but we keep on trying.
Steve
turbo2256b
Re: Holley jets
Post by turbo2256b » Thu Feb 15, 2018 1:27 pm
Nickerson Performance Competition Carburetors, Marine, Automotive, Motorcycle
try tis as they have been in cab mod business longest i know of
Think another one is C& S Specialties
