SBC Dyno results, where to go from here
rustbucket79
Re: SBC Dyno results, where to go from here
Post by rustbucket79 »
Stan, would you clarify what your math is saying?
rustbucket79
vortecpro wrote: Tue Feb 06, 2018 8:59 am
vortecpro wrote: Tue Feb 06, 2018 8:57 am You need to be looking at your drive line instead of the engine. How come no one does this?
133 MPH @ 3250=589 HP
Not mentioned yet is I am showing the best pull of a combo that is corrected. Track can see 3500’ days, and even within these tests we are talking 25, maybe 30 corrected up over what the engine made with my carb/header/full exhaust/etc
Stan Weiss
Vendor
Post by Stan Weiss »
rustbucket79 wrote: Tue Feb 06, 2018 3:37 pm Stan, would you clarify what your math is saying?
Based on calculations using the 4 column as A/F ratio I do not come up with some of the other data shown on the dyno sheet. If I use that other data on the dyno sheets I can get everything to come out the same but A/F ratio. Using the other fields I get 13.14:1 as the A/F ratio for the first line on the dyno sheet.
Stan
6.50camaro
Post by 6.50camaro »
I come up with around 12.7% converter slippage for 7200 rpm @ 134 mph with tire and gears listed. More gear will pick up converter efficiency with out raising rpm much.Dan
vortecpro
Post by vortecpro »
rustbucket79 wrote: Tue Feb 06, 2018 3:58 pm
I understand what you are saying.......but heres the problem, which comes back to the car setup 1320/133=9.92
rustbucket79
Stan Weiss wrote: Tue Feb 06, 2018 4:14 pm
Stan
Then this will explain your discrepancies. Our O2 sensors are a few years old and are due for replacement due to lead contamination. The other O2 reads a solid 1 to 1.5 numbers leaner, and swapping the leads side to side swaps the readings too. Some of the pulls showed as lean as 13.6 on the other channel at certain points.
rustbucket79
vortecpro wrote: Tue Feb 06, 2018 7:50 pm
Without a doubt the car is undergeared. When I originally built this engine I had 4.56's in the car but magnafluxing the gears showed cracks in the crown. I had a set of used 4.10's so that's what went in. I had planned to step up to 4.30's long before the dyno opportunity presented itself, but ultimately I'm gambling by staying with the 10 bolt diff, so an upgrade is happening in that department before the car hits the track again. Somewhere around 4.56's is what I'll use, it may well be faster with more, however I don't have national event track prep at my home track, so traction is of concern.
rustbucket79
6.50camaro wrote: Tue Feb 06, 2018 6:18 pm I come up with around 12.7% converter slippage for 7200 rpm @ 134 mph with tire and gears listed. More gear will pick up converter efficiency with out raising rpm much.Dan
You are correct, the variable is how much. I can tell you that my converter with 4.56's and a lower HP engine gave me around 5% slippage
rustbucket79
cspeier wrote: Tue Feb 06, 2018 10:06 am I just recently had a customer dyno a 13-1 421 with a 227cc head. I would post up the sheet if you would like to see it as long as folks don't think it's some sinister plot. lol
Feel free to do so. 8)
rustbucket79
Prior to the dyno, I had no clue just how well the power would hold on above 7000. I should probably pull it higher to see what happens at say 7800. :shock:
6.50camaro
rustbucket79 wrote: Tue Feb 06, 2018 8:45 pm
This past year I went from 4.56 to 5.13 gears , converter slippage went from over 19% to 11% this is for the 1/8th . Rpm went up 100 rpm at the stripe from 6600 to 6700. I don't know if I can go 5.38's and still stay below my self imposed limit of 7000. Dan
statsystems
Post by statsystems »
6.50camaro wrote: Tue Feb 06, 2018 9:40 pm
Seen this many, many times. Most,guys don't run near enough gear. Had a customer go from 4:30 to 5:13 with the same results you found. He really needed 5:38's but all the fence leaning bleacher preachers told him he was crazy and pretty much called him a liar.
rustbucket79
I wouldn't think .25 of a point would represent 300 RPM, but let me ask you this. Would the world end if you shifted at 7000 and crossed at say 7050 RPM? :mrgreen:
randy331
Post by randy331 »
You'd be surprised how deep of gear and how much converter you'll end up with if you chase ET only.
Most won't treat their engine the way it takes to produce lowest ET.
6.50camaro
rustbucket79 wrote: Wed Feb 07, 2018 12:00 am I wouldn't think .25 of a point would represent 300 RPM, but let me ask you this. Would the world end if you shifted at 7000 and crossed at say 7050 RPM? :mrgreen:
No I don't think it would. I have 4.56, 4.88, 5.13 gears on hand . I would have to buy the 5.38's . I was really looking to pick up converter efficiency to cut down on unnecessary heat in the trans fluid. I picked up a little mph .5 or so as an added bonus . If the 5.38's got the slippage down to 7-8% I'd be really happy with that. The thing is right now because the way the car is safety equipment wise I'm limited to no quicker than 6.50 in the 1/8th . The car went 6.43 first run off the trailer with this new combination. A couple changes to slow it down it went 6.31. Best the car did on the old motor was 6.96. Trying to be happy going 6.50 till I can upgrade the safety stuff. Then I won't need the 5.38's. Dan
