bearing damage
AC sports
bearing damage
Post by AC sports »
Finally pulled the bottom end out .
All bearings are conventional type steel/ alum.
All mains and rod bearings have same wear patterns.
Cratering/ dimpling. What do people make of it?
Looks like fatigue to me with bearings beginning to break down.
Would it be a side effect of oil starvation? Excessive load as the car has done quite a few circuit miles, or something I'm missing.
Cheers
202ci EH
Re: bearing damage
Post by 202ci EH »
That's debris embedded in the bearing, what do the journals look like?
Newold1
Re: bearing damage
Post by Newold1 »
I have always been told cratering in an engine bearing is fatigue failure of the bearing caused by using the wrong bearing type (makeup) for the application. I've never seen it in any engines I have opened though.
AC sports
Re: bearing damage
Post by AC sports »
Definitely doesn't look like there is anything embedded in the metal.
AC sports
Re: bearing damage
Post by AC sports »
Journals look perfect.
Newold1
Re: bearing damage
Post by Newold1 »
What exact bearing brand and style/part number?
Engine application and use?
CharlieB53
Re: bearing damage
Post by CharlieB53 »
I could easily be wrong, but to me that looks suspiciously a lot like the cavitation pitting I see on a boat prop from the air bubbles created, pulling molecules from the metal.
I would be checking the oil pump pick-up[ position in the pan, making double sure that it cannot suck any air at RPM.
AC sports
Re: bearing damage
Post by AC sports »
Bearings are FM std bi metal types. I suspect cavitation also. Maybe time for an accusump. The original sump wasn't baffled as well as I'd liked.
jed
Re: bearing damage
Post by jed »
CharlieB53 wrote: Sat Feb 03, 2018 11:26 am I could easily be wrong, but to me that looks suspiciously a lot like the cavitation pitting I see on a boat prop from the air bubbles created, pulling molecules from the metal.
X2-I agree on the could be cavitation??? That is very unusual pitting.
Barry_R
Re: bearing damage
Post by Barry_R »
Looks like cavitation to me as well. What is the application, clearance, etc.?
Looks like the crank is in contact for almost the full diameter.
Survival Motorsports
www.survivalmotorsports.com
Tuner
Re: bearing damage
Post by Tuner »
Any sign of detonation on the piston, edge of the head land or perhaps teeny black freckles on spark plugs? Is there any past history of the engine to think it may have been subject to detonation, such as low octane fuel or too much timing, too hot a plug, etc?
ProPower engines
Re: bearing damage
Post by ProPower engines »
That was just what I was thinking. Bi metal bearing the surface may not be as hard or strong as a A series or a tri metal bearing surface is has caused it to pit.
Re: bearing damage
Post by MadBill »
Barry_R wrote: Sat Feb 03, 2018 4:46 pm...Looks like the crank is in contact for almost the full diameter.
2X.
In fact it looks to be in contact right up to the chamfer at the parting joint. Pinching off the oil wedge that way might well cause/contribute to the blistering and would certainly invite failure. Either the bearing has insufficient eccentricity and/or the rod is oval at rest or dynamically.
AC sports
Re: bearing damage
Post by AC sports »
Finally got round to a proper inspection.
Found this in the bottom of rod bearing no. 3, and pits in number 1 main which is closest to the oil pump.
Can we conclude this is oil starvation & or cavitation?
AC sports
Re: bearing damage
Post by AC sports »
Crank pits.
