.. What is A/F going to tell me that jetting for best power and speed hasn't already told me? That it's jetted to lean?David Redszus wrote: ↑Thu Feb 01, 2018 11:59 amA lambda sensor on a wand inserted in the exhaust pipe is virtually useless because of ambient air leakage back into the pipe. So why does the engine not have proper lambda bungs brazed into the pipes at the correct location?Truckedup wrote: ↑Thu Feb 01, 2018 6:58 amThe pipes on my bike don't have sensor bungs so the thin wand was put up the exhaust pipe...The readings were way too lean for the power being made, 18-1..The operator changed O2 sensor but same result..The computer diagnostic said all was fine with the O2 stuff....Same thing occurred when I first built it and used another shop with a different dyno brand..David Redszus wrote: ↑Wed Jan 31, 2018 7:42 pm
Would you please explain what you mean by not getting a proper A/F reading?
What was the problem?
I don't find A/F readings at full throttle useful...There's no standard A/F for these engines,it's just one engine, I tune by best power on the dyno and best speed on the track while keeping alert for detonation...This isn't like a Chevy..The competitors are tight lipped .Running this vintage junk you're out there alone more or less to figure out what works...In fact the only real help I got was here on Speed Talk
A properly installed lambda sensor reveals much more than a simple A/F ratio (which it does not do). It will show engine misfires, shortstopping, transitional mixtures, mixture spikes, lean sports and much more. Do not look for a "standard" value since the correct mixture is dependent on conditions and specific blend of fuel used.
Vintage "junk" is not different than advanced engine development; you're on your own to figure out what works.
Air/ fuel ratio opinion
Re: Air/ fuel ratio opinion
Rich fuel ratios are often used for temperature control, detonation avoidance, throttle response and other reasons that have only a slight relation to maximum horsepower.A properly installed lambda sensor reveals much more than a simple A/F ratio (which it does not do). It will show engine misfires, shortstopping, transitional mixtures, mixture spikes, lean sports and much more. Do not look for a "standard" value since the correct mixture is dependent on conditions and specific blend of fuel used.
- jmarkaudio
It's all relative. If fuel is better vaporized early then distribution is better, so less overall/leaner mixture makes more power. And with better vaporization a larger carb can be used, or two carbs to lower pumping losses. At the carb shootout we were rule limited to individual cylinder peak O2's of 13.9, and the closer we got the more power it made.
Mark Whitener
www.racingfuelsystems.com
____
____
Dave I' understand what you are saying and I know you have way more experience than me with this stuff....I could do that and then using my A/F values from the track when the bike runs it's best speed to use that value when to rejet for different conditions as you say....David Redszus wrote: ↑Thu Feb 01, 2018 10:15 pmRich fuel ratios are often used for temperature control, detonation avoidance, throttle response and other reasons that have only a slight relation to maximum horsepower.A properly installed lambda sensor reveals much more than a simple A/F ratio (which it does not do). It will show engine misfires, shortstopping, transitional mixtures, mixture spikes, lean sports and much more. Do not look for a "standard" value since the correct mixture is dependent on conditions and specific blend of fuel used.
I'm only familiar with the size of O2 sensors commonly used in cars/trucks...The problem is anything like that sticking into to the exhaust pipe kills power on top end...The engine has two 1-1/2 x 34 inch individual pipes, no collectors or megaphones and imagine the restriction of an O2 sensor...Is there some other O2 option?
The Bosch 4.2 and 4.9 lambda sensors only require the very tip to be exposed.
During the many dyno pulls to tune the bike I tried to limit mid range reversion by inserting a 1/4 bolt 3/4 inch long near the pipe exits...Improved the bottom end by a few ft pounds and took the same off the top end...with only 55 rear wheel HP (40 ft lbs torque) to push a naked frame bike and rider with as much air drag as a car ? to over 130 mph , even one HP is precious...Warp Speed wrote: ↑Fri Feb 02, 2018 7:27 am The Bosch 4.2 and 4.9 lambda sensors only require the very tip to be exposed.
Engine performance as measured on a dyno is quite different than that developed on the track.Truckedup wrote: ↑Fri Feb 02, 2018 11:23 amDuring the many dyno pulls to tune the bike I tried to limit mid range reversion by inserting a 1/4 bolt 3/4 inch long near the pipe exits...Improved the bottom end by a few ft pounds and took the same off the top end...with only 55 rear wheel HP (40 ft lbs torque) to push a naked frame bike and rider with as much air drag as a car ? to over 130 mph , even one HP is precious...Warp Speed wrote: ↑Fri Feb 02, 2018 7:27 am The Bosch 4.2 and 4.9 lambda sensors only require the very tip to be exposed.
Assuming a vehicle with a frontal area of 8.0 ft^2, a Cd of 0.42, we still need to know the ambient air conditions.
Further assuming a baro of 29.0 inHg, 80F deg, and RH of 30%, at 130 mph it would take 45.8 hp to overcome aero drag.
As mentioned earlier, a lambda need not be fully inserted into the pipe to obtain adequate readings.
It depends on how you do it.Belgian1979 wrote: ↑Fri Feb 02, 2018 3:18 pm you make it sound as if using a dyno for tuning is irrelevant
Like dynoing a car that's got a hot air sucking pod filter on it.
Dynoing it with the bonnet open when it's closed when you drive it.
Does that make any sense?
http://www.ebay.com/bhp/o2-sensor-spacerDavid Redszus wrote: ↑Fri Feb 02, 2018 11:56 am...As mentioned earlier, a lambda need not be fully inserted into the pipe to obtain adequate readings.
They function properly if not projected into the pipe at all, let's say the tip is flush with the pipe wall?.......You guy mentioning the chassis dyno.....My bike runs it's record breaking speed at the track exactly as tuned on the chassis dyno. Changing tuning at the track offered no improvement other than gearing...I know this normally may not be the situation ...MadBill wrote: ↑Fri Feb 02, 2018 8:44 pmhttp://www.ebay.com/bhp/o2-sensor-spacerDavid Redszus wrote: ↑Fri Feb 02, 2018 11:56 am...As mentioned earlier, a lambda need not be fully inserted into the pipe to obtain adequate readings.
The portion with the multiple holes should be flush with the pipe id, leaving just the center tip exposed. This will keep influence to output at a minimum, and also help with overheating during extended high temp use.Truckedup wrote: ↑Sat Feb 03, 2018 7:27 amThey function properly if not projected into the pipe at all, let's say the tip is flush with the pipe wall?.......You guy mentioning the chassis dyno.....My bike runs it's record breaking speed at the track exactly as tuned on the chassis dyno. Changing tuning at the track offered no improvement other than gearing...I know this normally may not be the situation ...MadBill wrote: ↑Fri Feb 02, 2018 8:44 pmhttp://www.ebay.com/bhp/o2-sensor-spacerDavid Redszus wrote: ↑Fri Feb 02, 2018 11:56 am...As mentioned earlier, a lambda need not be fully inserted into the pipe to obtain adequate readings.
Not sure about the re-locators Bill posted above, but I would imagine they could lend to false readings and slower reactions but?
I feel if the testing is done properly, a dyno can give relative information for the track. Especially in low g force environments.
I have a question. my base motor runs on m1 alcohol mechanical injection, but nitrous system runs on C23 gasoline. what do i set my racepak sensor to read for best results > gas or alcohol
Using just an 02 value for tuning the air/fuel ratio is only an indication, not actuality.
Seems to me (but I'm prepared to be wrong) that if you selected λ rather than AFR, you'd be covered regardless of the fuel mix.
