Hi, Is there anyone that can help me out with some dimensions for a SBC Crankshaft flywheel boss (one piece seal type)? What I've got so far is that the diameter is 95mm, the bolt circle is Ø3.0", the bolts are 7/16" @ 20TPI and that's about all.I've spent 2 days looking online but no one seems to list that info and I don't have access to an SBC either. I check "GradCAD" but that's mostly rubbish.
https://www.google.com.au/search?tbm=is ... 0Ao89cI4TM:
SBC Crankshaft flywheel boss dimensions
