Baseline NGK racing plug for 11.5-1 sbc
redliner
Post by redliner »
I am building a Speier headed, Jones .700ish 262/268 @ .050 lift solid roller cammed 414 sbc. I am going to dyno it and wondered where to start with NGK plugs 6,7,8 ? I would like to bring plugs with me to cover different heat ranges I might need to dial the engine in.This motor will run on 100 octane aviation fuel.
bigjoe1
Show Guest
Show Guest
Re: Baseline NGK racing plug for 11.5-1 sbc
Post by bigjoe1 »
The compression ratio is what tells you the plug heat range requirement- What is it ?
JOE SHERMAN RACING
Krooser
Post by Krooser »
bigjoe1 wrote: Sun Jan 21, 2018 4:58 pm The compression ratio is what tells you the plug heat range requirement- What is it ?
JOE SHERMAN RACING
Joe...11.5 in the headline...we are all getting old!!!
jcisworthy
Post by jcisworthy »
I usually run one heat range colder than the HP I think it is going to make
bigjoe1
Show Guest
Show Guest
Post by bigjoe1 »
I missed that ! -6 would be pretty safe-- I use -5 all the time in the street racer stuff I build-- It will not make any difference on the dyno- Hotter seem to last longer-- Look at the ground strap after a dyno pull
JOE SHERMAN RACING
redliner
Post by redliner »
JOE SHERMAN RACING
Heck I thought I forgot to list it also! It is 11.5-1
bigjoe1
Show Guest
Show Guest
Post by bigjoe1 »
I am 77 years old- What is your excuse ?
JOE SHERMAN RACING
redliner
Post by redliner »
bigjoe1 wrote: Sun Jan 21, 2018 6:29 pm I am 77 years old- What is your excuse ?
JOE SHERMAN RACING
I have/ do bump my head ALOT...
redliner
Post by redliner »
bigjoe1 wrote: Sun Jan 21, 2018 5:33 pm I missed that ! -6 would be pretty safe-- I use -5 all the time in the street racer stuff I build-- It will not make any difference on the dyno- Hotter seem to last longer-- Look at the ground strap after a dyno pull
JOE SHERMAN RACING
Thanks Joe!
jcisworthy
jcisworthy wrote: Sun Jan 21, 2018 5:28 pm I usually run one heat range colder than the HP I think it is going to make
Just to clarify, 600HP start with a 7 heat range
Geoff2
Post by Geoff2 »
What Joe said, use the -6 heat range.
jmarkaudio
Vendor
Post by jmarkaudio »
At that compression 6 should work fine for street and drag, unless you run for an extended time at higher RPM's and temps temps like an oval track or road course, then try a 7.
Mark Whitener
www.racingfuelsystems.com
____
redliner
Post by redliner »
Thanks guys! 6 it is!
redliner
Post by redliner »
The coldest 14mm 3/4 reach NGK racing plug I find is R5671-7, so I guess that is what I must baseline it with...
gnicholson
Post by gnicholson »
Does ngk make a short plug like the 5671 in a resister model with a hotter heat range like a 5 or 6
