exhaust on a limited circle track class
Krooser
Re: exhaust on a limited circle track class
Post by Krooser »
Vacuum and lift rules?
If you have the budget angle mill those heads to get some compression and talk to Mike Jones about your cam...
englertracing
Post by englertracing »
This is the guy I buy bends from https://ptbtubebending.mysparkpay.com
Walking in with cash is the way to go if local....
I would use mandrel would put the biggest open chamber mufflers you can fit under the car as close as possible to the headers.
Maybe even some giant empty gutter flow master big block jobbers, empty 55 gallon drum if you catch my drift.
phantomfab
Post by phantomfab »
Krooser wrote: Sun Jan 21, 2018 10:27 pm Vacuum and lift rules?
yes we have a .450 lift rule with a 16 in @1000 rule.
phantomfab
http://www.salinahighbanksspeedway.com/ ... x?i=416763
there's the rules for anyone interested.
