421 cube pulling truck engine
Locked
randy331
Re: 421 cube pulling truck engine
Post by randy331 »
cjperformance wrote: Mon Jun 18, 2018 12:02 am Nice, i can see that being a very costly sport!
It's not free, but really the truck has held up well. A few u joints till we got the angles sorted and went to better ones and broke the tranny at Diaganal last year.
We been winning enough to pay for race gas and tow gas so far this year. I seldome did that drag racing.
I could just sit at home and post theory and ideas on ST instead of truck pulling, that'd sure be cheaper, :D and I'd probably win more too !!! :lol: :lol:
CGT
Post by CGT »
randy331 wrote: Mon Jun 18, 2018 9:25 am
If you want to be taken more seriously, you need to have very, very long posts! Like the pro's. :lol:
cjperformance
Post by cjperformance »
:lol:
randy331
Post by randy331 »
Took the pulling truck up to the local grain elevator to scale it.
Front axle = 5050 LB
Rear axle = 1130 LB
Is this good for a no weight box in front of the bumper class ?
What would you like to see as far as right to left weight split ?
mdabbott2009
Post by mdabbott2009 »
Don’t hold me to it but I believe one of the guys that help build some of the mopar chassis said there at 1200 on the rear axle with box on
GARY C
Post by GARY C »
randy331 wrote: Fri Jun 22, 2018 10:34 am Took the pulling truck up to the local grain elevator to scale it.
Rear axle = 1130 LB
It seems the best weight placement would vary from track to track and even at times from pull to pull.
MaxFlow
Post by MaxFlow »
One more air cleaner and that thing would have won! Lol
Looking real good!
Joe Stalnaker
WV
cjperformance
MaxFlow wrote: Wed Jun 27, 2018 7:31 pm One more air cleaner and that thing would have won! Lol
Looking real good!
Needs a salad bowl !
randy331
Post by randy331 »
https://www.youtube.com/watch?v=-bsOuBwQ2fw
In cab video of our pull Sat. at Burlington Junction, MO.
NWMO pullers ass. sanctioned pull.
The 3 IAMO trucks that were there took top 3 spots.
The 2 trucks to left of him as he leaves the track are other 2 IAMO trucks.
Old School
Post by Old School »
Pretty impressive. He kept it on the edge of the shift light for about 18 seconds. Good smooth driving. Shut it down without abuse.
I know nothing about truck pulling. How much maintance is the clutch? What is the clutch life?
Engine sounds great. How many of the other trucks are small blocks?
Billy
randy331
Post by randy331 »
Old School wrote: Sun Jul 01, 2018 4:31 pm Pretty impressive. He kept it on the edge of the shift light for about 18 seconds. Good smooth driving. Shut it down without abuse.
It was full throttle a few seconds in to the pull. It just has that much load on it that it took it that long to turn the shift light on. Rev limiter is 9200 rpm and you can here it bump it just a bit and it turns the shift light back off for a bit. Shift light is 300 rpm below rev limit so in case the track is loose and it turns on shift light at half throttle you know not to add any more.
Old School wrote: Sun Jul 01, 2018 4:31 pm I know nothing about truck pulling. How much maintance is the clutch? What is the clutch life?
Clutch holds up real well. Came from Trav's 4x4. Same stuff he runs in his pro stock pulling truck.
Has .030" wear after all of last season. Just shimmed it up.
Old School wrote: Sun Jul 01, 2018 4:31 pm Engine sounds great. How many of the other trucks are small blocks?
One other truck that pulls with IAMO is small block.
I think just one other small block at this pull.
steve316
Post by steve316 »
the pull looks like it is less abusive than I though it would; being at that rpm for 18 sec. The motor sounded great. =D>
CGT
Post by CGT »
Bad af! Moo
BLstangin
Post by BLstangin »
I'm just curious what kinda oil you guys run and how much pressure you use at that kinda rpm for substained time like that.
70 mustang coupe restored with the help of my Dad and LOTS of friends. 306 490hp/398ft lbs t56 magnum 5.00 gear
1986 F150 standard cab short bed build in progress!
randy331
Post by randy331 »
BLstangin wrote: Sun Jul 01, 2018 7:48 pm I'm just curious what kinda oil you guys run and how much pressure you use at that kinda rpm for substained time like that.
Engine has driven XP7 in it currently.
50-60 psi oil pressure.
Locked
