best place to purchase 260 lb. injectors?
best place/price to purchase 260 lb/hr injectors for e85 turbo application. Any ideas on what kind are best and where to get for decent $?
Re: best place to purchase 260 lb. injectors?
These are not 260's but I found Bosch 220's for about $50.00 each on Ebay.
The really large ones are quite expensive.
I'm looking to upgrade from 160's myself.
Won't help the OP, but I know of someone selling new atomizer 225's. he has two new sets of nine for 1k a set.blwilliams wrote: ↑Thu Jan 18, 2018 5:37 pm These are not 260's but I found Bosch 220's for about $50.00 each on Ebay.
- midnightbluS10
Make sure you're buying authentic Bosch injectors. Just had this discussion on another forum and the Chinese Bosch copies locked up at only 15psi more than test pressure, which was about 55PSI, IIRC. So they locked up at 70psi or less.blwilliams wrote: ↑Thu Jan 18, 2018 5:37 pm These are not 260's but I found Bosch 220's for about $50.00 each on Ebay.
JC -
OK thanks for the tip. How do you tell between original and counterfeit?midnightbluS10 wrote: ↑Fri Jan 19, 2018 2:53 amMake sure you're buying authentic Bosch injectors. Just had this discussion on another forum and the Chinese Bosch copies locked up at only 15psi more than test pressure, which was about 55PSI, IIRC. So they locked up at 70psi or less.blwilliams wrote: ↑Thu Jan 18, 2018 5:37 pm These are not 260's but I found Bosch 220's for about $50.00 each on Ebay.
