Interesting the rear cap is drilled but the hole is smaller than what any I have seen...... I'll take some pictures this weekend and try and post. All the holes are plugged where you would run the dry sump lines to.. HMMMracear2865 wrote: ↑Fri Jan 19, 2018 11:19 am I have one here now with a hole in the side the size of my fist. Am welding up now and I too worrying about line hone as Ive done 2 before and they are a bitch. You could get a cap drilled for oil as I had one here recently. They would do about anything you wanted on request.
reed
Rodec block Questions?
- af2
Re: Rodec block Questions?
GURU is only a name.
- af2
Yep definitely can run a wet sump. Hole is through the cap and intersects through the block. The hole in the cap was plugged (glasses are my friend LOL). The bearings are perfect and there is no sign of cap fretting at all. Working on the pan kick out now...
Filter???
Filter???
Forgive my ignorance; but maybe you could try AJPE (Alan Johnson Performance Engineering)? They bought Rodeck in 05 or 06 I think.
- af2
That was my next go to. I hate calling if it could be answered in a forum.
