Crankshaft ID
- sheppard00
Crankshaft ID
Need help identifying this crank. Already tried scat' s website, and a couple hrs on the net with no avail.
mark sheppard
I may not know, but I can find someone that does.
- sheppard00
Re: Crankshaft ID
It is a 3.48 stroke. I'm trying to figure out what metal it's made out of.
mark sheppard
- sheppard00
Re: Crankshaft ID
Another pic
mark sheppard
Re: Crankshaft ID
Guess you could smack the part with a wrench hung on a wire or supported by a small point. steel will go RINGGGGGGGGGgggggggg....... ductile iron will go DING.. cast iron will go THUD. ymmv..
- sheppard00
Re: Crankshaft ID
Definitely rings. Have a cast scat crank here also, as well as some stock cranks to compare.
mark sheppard
- sheppard00
Re: Crankshaft ID
Scat contacted me back. Current pn is 435034805700 so it's a descent crank.
mark sheppard
