Valve pockets
1972ho
Re: Valve pockets
Post by 1972ho »
I thought the bowl/pocket was diverging part of the port after velocity has been increased through the smallest part of the port.
1972ho
Re: Valve pockets
Post by 1972ho »
dave brode
Re: Valve pockets
Post by dave brode »
72 ho, what's the blue stuff?
Thanks.
Dave
midnightbluS10
Re: Valve pockets
Post by midnightbluS10 »
1972ho wrote: Thu Jan 18, 2018 10:46 am The bowls in these heads have already been ported and cleveland bowls have not that’s why they look a little different.
That's not what I meant. He says the modular heads don't have valve pockets. Yet they look visually similar to heads that "have valve pockets". So if those aren't valve pockets, what are they? They sure look like pockets to me? When people do pocket porting on 4v modular heads, that's the area they work. So? According to the OP, modular heads don't have valve pockets. So what are those if they're not valve pockets? What makes them different than the Cleveland heads?
Personally, they look to both look relatively the same in those pics, minus the obvious clean metal from recent port work.
JC -
midnightbluS10
Re: Valve pockets
Anybody?
I still don't get why you're saying mod motor heads don't have valve pockets. They look just like heads with valve pockets so what makes these different? What do you see or not see that makes you think they don't?
JC -
ptuomov
Re: Valve pockets
Post by ptuomov »
This engine didn't like a "bowl" or whatever, even when the flow bench liked it:
Put Search Keywords Here
Krooser
Re: Valve pockets
Post by Krooser »
Pocket....bowl. Tomato... Tomaato...
turbo2256b
Re: Valve pockets
Post by turbo2256b »
this is more like the valve pocket i was thinking of the section above with the port angle and such would not need or be helped with same changes
