cam spauling: Can I run this?
I have this roller cam I want to run it my street driven 327, its 262/266@050 .645 gross. 1.5 rockers, springs are 200 on the seat, 435 over the nose, steel 2.02sx1.60s, steel retainers and I am running a rev kit. It sees 7500 rpm. There is some spauling on one lobe, can I run this? Or repair? Grind out the damage, tig the pit, and get one lobe reground? I like this cam and budget is an issue. Thoughts?
Re: cam spauling: Can I run this?
Can't run that on a roller. For just a drag car it will last a little while, but destroy roller.
Is it custom ground or off the shelf.
Can be welded and ground depending on material. But that lobe will be slightly different
That belongs in the scrap bin.
Thanks, I think that is what I will try. Grind the pit out with a small bit in my Foredom, tig it up, and take to my local cam guy and get the lobe reground. The base circle will be a little smaller, but I don't see that as a big hairy deal. @statsystems, how much spring do you think I need?williamsmotowerx wrote: ↑Sun Jan 14, 2018 3:18 pm Can't run that on a roller. For just a drag car it will last a little while, but destroy roller.
If the surrounding area of the lobe gets too hot, you will be annealing that area, and you will have more issues.falcongeorge wrote: ↑Sun Jan 14, 2018 4:49 pmThanks, I think that is what I will try. Grind the pit out with a small bit in my Foredom, tig it up, and take to my local cam guy and get the lobe reground. The base circle will be a little smaller, but I don't see that as a big hairy deal. @statsystems, how much spring do you think I need?williamsmotowerx wrote: ↑Sun Jan 14, 2018 3:18 pm Can't run that on a roller. For just a drag car it will last a little while, but destroy roller.
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
Can that be ground out?CamKing wrote: ↑Sun Jan 14, 2018 5:01 pmIf the surrounding area of the lobe gets too hot, you will be annealing that area, and you will have more issues.falcongeorge wrote: ↑Sun Jan 14, 2018 4:49 pmThanks, I think that is what I will try. Grind the pit out with a small bit in my Foredom, tig it up, and take to my local cam guy and get the lobe reground. The base circle will be a little smaller, but I don't see that as a big hairy deal. @statsystems, how much spring do you think I need?williamsmotowerx wrote: ↑Sun Jan 14, 2018 3:18 pm Can't run that on a roller. For just a drag car it will last a little while, but destroy roller.
It looks big for the engine combo anyway.
It might run forever like that, or it might not.....I don't know.
But if you weld it, I think it will fail for sure.
No. The reason it pitted, is because they ground too much of the heat treat away. The hardened face, is too thin, and the softer backing material has given way, so the hard face cracks and flakes off.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
a follow up, I sent the same set of pics to Marco, at Shadbolts, the cam grinder that I usually deal with on stuff like this, he says "no problem, we fix this all the time, tig it up and we will re-grind the lobe". So I guess we will see what happens.
