409 vs 415 SBC
Re: 409 vs 415 SBC
My vote for the old standard 3.75x4.155 only giving up 3ci from what you want and not as much clearance issues. Still plenty of meat left in the bores if you hurt it too. Surely the rotating assembly will be cheaper and shelf pistons. Probably the difference you would pay shelf piston vs custom would cover the bore and hone.
Just figure up some exotic combo that would make 406 CI and tell everyone that's what it is.
- New Member
Re: 409 vs 415 SBC
If you go with a 3.875 stroke and a 283 ( 2"0 ) rod. you can run a standard base circle cam. the rods I use are com-star and I have .050 to .045 rod to cam clearance.
Re: 409 vs 415 SBC
I consider .850 a small base circle but you'll have a hard time finding one that small. A true .900 will work for you i also consider a small base circle. Be careful many "so called" small base circle .900s will be closer to .930.Most cam company's shy away from smaller cores because they don't have that small a core in stock to work with. They'll have to get one. Also they have more flex,not as strong and all that stuff. I've used them for years with no problem but trust me it's not what you want to do! In your application with 3.875 stroke and stock cam location your gonna be to close. Probably gonna have rod to cam contact "unless you use small base circle.900". Just grind your rods for clearance! Don't look pretty but works fine. If it were me i'd agree with most on here and resist the urge and just go with 3.75 stroke for many reasons. If you insist on small base circle i'd use Bullet. They will listen to you and produce what you want.tracyracin wrote: ↑Tue Jan 09, 2018 3:37 pmWhat is considered a "small" base circle? Lunati have some cams that are .900"Reef wrote: ↑Tue Jan 09, 2018 11:53 am A small base circle will be necessary. I would consider a cam of 260°I/268°E at .050"tappet rise on a 106°or 108° separation installed at 102°to 104°ILC with .430" to .450" lobe lift a pretty straight forward choice. I would shoot for 14/1 c.r. I am only one engine builder, a good cam grinder talks to many , gaining input, receiving feedback, utilizing very specific knowledge and experience to give the Best advise/product. Again to each his own and happy racing!
- New Member
- New Member
Re: 409 vs 415 SBC
I assume that you grind your rods down to clearance the cam before you have the rotating assembly balanced?geraldtson wrote: ↑Tue Jan 09, 2018 8:09 pmI consider .850 a small base circle but you'll have a hard time finding one that small. A true .900 will work for you i also consider a small base circle. Be careful many "so called" small base circle .900s will be closer to .930.Most cam company's shy away from smaller cores because they don't have that small a core in stock to work with. They'll have to get one. Also they have more flex,not as strong and all that stuff. I've used them for years with no problem but trust me it's not what you want to do! In your application with 3.875 stroke and stock cam location your gonna be to close. Probably gonna have rod to cam contact "unless you use small base circle.900". Just grind your rods for clearance! Don't look pretty but works fine. If it were me i'd agree with most on here and resist the urge and just go with 3.75 stroke for many reasons. If you insist on small base circle i'd use Bullet. They will listen to you and produce what you want.tracyracin wrote: ↑Tue Jan 09, 2018 3:37 pmWhat is considered a "small" base circle? Lunati have some cams that are .900"Reef wrote: ↑Tue Jan 09, 2018 11:53 am A small base circle will be necessary. I would consider a cam of 260°I/268°E at .050"tappet rise on a 106°or 108° separation installed at 102°to 104°ILC with .430" to .450" lobe lift a pretty straight forward choice. I would shoot for 14/1 c.r. I am only one engine builder, a good cam grinder talks to many , gaining input, receiving feedback, utilizing very specific knowledge and experience to give the Best advise/product. Again to each his own and happy racing!
Re: 409 vs 415 SBC
my $.02 would be that i wouldnt try to run a small base circle and a lot of rpm. id run a 3.5" stroke and standard base circle and turn it 7600. i mean, if you can get away with a 3.625 and a standard base circle that would work.
You wont beat anyone if you do everything the same as everyone.
- New Member
Re: 409 vs 415 SBC
Is it a risk to run 8k or 8200 with a small base circle cam? I definitely need some sort of reliability cause I can only do this once this season LOL
Re: 409 vs 415 SBC
tracyracin wrote: ↑Tue Jan 09, 2018 8:17 pmI assume that you grind your rods down to clearance the cam before you have the rotating assembly balanced?geraldtson wrote: ↑Tue Jan 09, 2018 8:09 pmI consider .850 a small base circle but you'll have a hard time finding one that small. A true .900 will work for you i also consider a small base circle. Be careful many "so called" small base circle .900s will be closer to .930.Most cam company's shy away from smaller cores because they don't have that small a core in stock to work with. They'll have to get one. Also they have more flex,not as strong and all that stuff. I've used them for years with no problem but trust me it's not what you want to do! In your application with 3.875 stroke and stock cam location your gonna be to close. Probably gonna have rod to cam contact "unless you use small base circle.900". Just grind your rods for clearance! Don't look pretty but works fine. If it were me i'd agree with most on here and resist the urge and just go with 3.75 stroke for many reasons. If you insist on small base circle i'd use Bullet. They will listen to you and produce what you want.tracyracin wrote: ↑Tue Jan 09, 2018 3:37 pm
I assemble and check then disassemble and grind as needed. Can grind before (preferably) or after balancing. Never had a balance issue grinding after rotating assembly had been balanced. If you're gonna use 4-7 swap might want to clearance with both firing orders in mind. I only grind rods that need to be ground. If you're gonna be swapping cams later in car you might want to take a little off each rod to gain clearance for different cams. Might save a motor down the road somewhere. Still i'd go with 3.75 for many reasons in you're circle track. Be more clearance everywhere and more durable which is what you need.
Re: 409 vs 415 SBC
There will only be a few hp difference in any of the bore stroke combo mentioned.If you aren't required to run 23 degree heads that is where I would spend the money.When I went from 23 to -12 brodix It didn't extend the rpm range much, it put a lot more torque and hp under the curve.For reliability and budget I would limit myself to 7800.
Re: 409 vs 415 SBC
Yes its a risk compared to larger base circle. Weaker all the way around especially for circle track " think durability". Real small base circle leaves lifters sitting much further down in the hole which also means extra long pushrods.For drag racing you'd be fine but for round dee round it'll cause you problems. For higher rpm and durability you'd want fatter cam and shorter pushrods!tracyracin wrote: ↑Tue Jan 09, 2018 8:32 pmIs it a risk to run 8k or 8200 with a small base circle cam? I definitely need some sort of reliability cause I can only do this once this season LOL
Re: 409 vs 415 SBC
4.100" is not a popular bore size at all. You would be much better off running a 4.155" or 4.185" bore size - much easier to find pistons and rings in these sizes . . . . . .
Bill
SAE Member (30 years)
Re: 409 vs 415 SBC
Use a long piece of heavy lead solder, "wire", that should be right at .100" in dia.
Just thread it along each rod and turn the engine over by hand watching the pinch between the cam, rod and solder wire. Remove and mic the pinch to give you the clearance amount.
Works like a charm.
Re: 409 vs 415 SBC
Randy at Race Tec pistons will be very helpful. They have no problem with bore size mods.If you need the pistons right away just ask they will do it. I like pdk67 method for cam to rod check , never done it that way but great idea, I have long feeler gauges I have also cut a long strip of cardboard about the width of a lobe. Might as well grind before balancing IF you end up needing to grind be sure to finish nicely. I have a shot peener to final recompact the surface glassbead would be an ok alternative, not the end of the world if you can't do either just nicer. You will not have a reliability problem just get a .900"B.C. it's done every day in engines that last 20+ nights going round and round at 8200rpm and more . I try and keep as much base as possible but sometimes you deal with the parameters in front of you.
