Wow, I fooled with the big Olds engines, but not the small. I don't remember the big ones having the pistons so far down.
The advantage of edel/pro-comp heads aside, The B, C etc heads on a high-ish rpm, dome piston small block Olds has always appealed to me. A bit more wow factor potential vs the 5s, 6s etc. I wonder how much hassle it would be to use a domed sbc piston?
Fwiw, I remember as a teen, gleefully realizing that the 425 piston had the same C.H. as the 350. I'm a third generation Olds guy. Dave Smith, a mentor of Bill Travato, was my hero.
I hope to have another Olds before I die.....
Dave
Budjet 350 olds
Re: Budjet 350 olds
I hope that the OP doesn't mind me going back 30+ years...
Circa 1985
Circa 1985
Re: Budjet 350 olds
My 455 GTO from the same time frame.
Re: Budjet 350 olds
Just an FYI- I now have a new Mahle Motorsport piston available for 350, 400E, and 425 Olds. They're available in 4.065, 4.100 and 4.155 bore sizes, made of 4032 material and have 10cc valve reliefs. Compression distance is 1.625. I'll have H beam rods for the small blocks available on or about April 1 as well.rocketracer380 wrote: ↑Tue Jan 09, 2018 9:58 am SBC pistons are I believe 1.565/1.57 my combo requires a 1.57 for .01 Deck should be at .01/.015 in the hole with a 6" rod and a 3.500 stroke if my math is correct
Thanks.
Engine Builder, Accel, AEM, Comp, Erson, Holley, and Lunati Dealer
Re: Budjet 350 olds
Budjet build no money for forged pistons hypers are more than adequate for this stockish rebuild yes I'm aware. Of new rods and pistons available.
Re: Budjet 350 olds
Beautiful A body! Gives me nightmares of the old days... working on the diesel castings!dave brode wrote: ↑Tue Jan 09, 2018 12:11 pm I hope that the OP doesn't mind me going back 30+ years...
Circa 1985
- Rick Finsta
Re: Budjet 350 olds
Thanks for working on those diesel castings, but sorry to hear it gives you nightmares. It's great having $75 junkyard blocks that will take a few thousand horsepower!
Mike Gallo, President
