Believe it! LOLDaveMcLain wrote: ↑Mon Jan 08, 2018 1:29 pm I can't believe that small amount of difference would really matter enough to measure performance wise.
SBC Shaft Mount Geometry with different int/exh lifts
Re: SBC Shaft Mount Geometry with different int/exh lifts
.030 is .015 each way, come on...Warp Speed wrote: ↑Mon Jan 08, 2018 2:20 pmBelieve it! LOLDaveMcLain wrote: ↑Mon Jan 08, 2018 1:29 pm I can't believe that small amount of difference would really matter enough to measure performance wise.
His geometry problem, probably not gonna be a factor. Doesn't mean it's correct but.....DaveMcLain wrote: ↑Mon Jan 08, 2018 2:33 pm.030 is .015 each way, come on...Warp Speed wrote: ↑Mon Jan 08, 2018 2:20 pmBelieve it! LOLDaveMcLain wrote: ↑Mon Jan 08, 2018 1:29 pm I can't believe that small amount of difference would really matter enough to measure performance wise.
I assumed, since you didn't quote anyone, you were referring to Bills post right above yours, (not the general thread subject) in which my statement would still stand.
Thanks Bill! This is a nitrous engine (400hp jets though a plate), never runs N/A, and from what I am being told by the nitrous gurus helping me, the more the lift on intake the better to stuff as much nitrous as possible as quick as possible. 1.7 it is!
You should assemble it and see what you have.Using mid lift you are not looking at the cam at max lift.
That's a split as they say. You're gonna have to make compromises here so I agree with the "meet in the middle" approach. You're smacking alot of nitrous in there so maybe focus a little bit more on not compromising the exhaust side. Ain't valvetrain fun?
By saying to not compromise on the exhaust side, you mean to sit the difference but pay more attention to the final geometry (rocker sweep) and final net valve lift on the exhaust and tweek slightly if required to get as perfect as possible, even if I lose a little on the intake?
Yes that's correct. Pardon my poor choice of wording. If the cam was more even lift both sides I'd say split the difference through and through.lekid wrote: ↑Tue Jan 09, 2018 1:41 pmBy saying to not compromise on the exhaust side, you mean to sit the difference but pay more attention to the final geometry (rocker sweep) and final net valve lift on the exhaust and tweek slightly if required to get as perfect as possible, even if I lose a little on the intake?
I'd lean the other way. The intake is more critical for power, needs more lift and is usually heavier so should get the nod re any required compromises. That said, there still isn't enough here to merit much agonizing.
Thanks guys. Very appreciated!
Speedtalk FTW...again!!
Yeah, normally I'd say get the intake closest and the exhaust is what it is. With this I'd say split it for dummy up purpose, asses PTVC, then if good err on the 'get the exhaust right ' side of things.
Did the geometry based on the splitting the difference and it is actually extremely close to the 90deg at mid-lift on the exhaust. I did not do the intake yet, still waiting for the new intake rockers since it requires a different offset for this head.
Here is a picture of my exhaust sweep
What does the sweep measure?lekid wrote: ↑Fri Jan 12, 2018 11:19 am Did the geometry based on the splitting the difference and it is actually extremely close to the 90deg at mid-lift on the exhaust. I did not do the intake yet, still waiting for the new intake rockers since it requires a different offset for this head.
.065" ish by the lookredliner wrote: ↑Fri Jan 12, 2018 4:41 pmWhat does the sweep measure?lekid wrote: ↑Fri Jan 12, 2018 11:19 am Did the geometry based on the splitting the difference and it is actually extremely close to the 90deg at mid-lift on the exhaust. I did not do the intake yet, still waiting for the new intake rockers since it requires a different offset for this head.
I did not measure it, but since the valve is 11/32, it looks to me like it is roughly 0.060-0.065".
