How much more 427 SBF
Autopart101
Post by Autopart101 »
Making some changes this winter. Old combo made 457whp @5800. when it was EFI. Now changing to carb. Hope I get 100 more HP with the new combo. Any ideas on if I will hit my goal?
Old combo
427 10.8-1
vic jr heads OOTB
HR cam 242-252 @.050 .598 lift
1.7 rr
SV intake
90TB
1 3/4 LT
New Combo
427 11-1
AFR220
1.7 SMR
SR Cam 260-266 @.050 .70 lift
EDEL 2828 intake
1050 Dom carb
1 3/4 LT
Mark O'Neal
Re: How much more 427 SBF
Post by Mark O'Neal »
You'll go way past with just the head and cam change.
I figure the Vic Jr for about 525 FWHP, then use a different head.
427dart
Post by 427dart »
Is this street or race? May have some tuning to get the big 4500 carb to cruise well. A 1 7/8 or 2 inch header size would help too.
cab0154
Post by cab0154 »
thats a lot of cam for that little compression. I would personally just use the intake you have, port match it and have some plenum work done because to run right the 2828 will require quite a bit of work. the super victor can support 700hp.
You wont beat anyone if you do everything the same as everyone.
Autopart101
I also have a Holley 950. I may use it if the 1050 is too much. I like the 2828 over the SV. I have both. Yes there is a lot of plenum work to be done in the 2828. My goal is to make 650+ FWHP.
CGT
Post by CGT »
I
I like the 2828 on that cubic inch. Plenum work isnt too bad to do in my opinion. Good luck. I think youll meet your goal.
CGT
Post by CGT »
I did a 4.125 x 4.0 sbf. 225 AFR's untouched, 13.5 comp, 2828, 1050 dominator. 266-280 cam.
Has went 6.0 115@2950lbs with a bit of throttle stop on the hit for traction.
Autopart101
CGT wrote: Sun Jan 07, 2018 5:06 pm I did a 4.125 x 4.0 sbf. 225 AFR's untouched, 13.5 comp, 2828, 1050 dominator. 266-280 cam.
Thats great numbers from that combo!! What rpm did you shift?
CGT
Post by CGT »
Autopart101 wrote: Sun Jan 07, 2018 5:26 pm
He is a serious bracket racer. It shifts on a timer but generally between 6600 and 7000rpm.
I think it needs shifted higher but he is scared. Hope to have it on the engine dyno this winter. We ran out of time to before racing started.
I Plan on playing with the belt drive and seeing if we cant calm it down a bit down low and run it up higher to get in the 5's. It has a best 60ft of 1.25.
Autopart101
CGT wrote: Sun Jan 07, 2018 6:05 pm
good times for that CFM head. We have a 71 cougar backet car stock block 505 BBF 3000lbs runing 5.60s 121mph. with 400 cfm and single dom. 15-1 with a glide. Also run a rail 632 BBF A heads flow 470s 1450 dom running 4.50s.
randy331
Post by randy331 »
CGT wrote: Sun Jan 07, 2018 6:05 pm I think it needs shifted higher but he is scared. Hope to have it on the engine dyno this winter.
He won't shift it higher but will pull it out of the car to rev it higher on the dyno ?
Cougar5.0
Post by Cougar5.0 »
Autopart101 wrote: Sun Jan 07, 2018 3:24 pm I also have a Holley 950. I may use it if the 1050 is too much. I like the 2828 over the SV. I have both. Yes there is a lot of plenum work to be done in the 2828. My goal is to make 650+ FWHP.
I feel Mark may be right above to point out that the heads were most limiting on your previous combo. Shafiroff says they'll send you a dyno sheet with the linked engine (427W) showing 630FWHP on a combo that is essentially your old setup with the addition of AFR220's (and open header exhaust we'll assume.) Their cam is only slightly larger than your old cam.
F-BIRD'88
Post by F-BIRD'88 »
All these BIG single plane racing intakes (especially the 4500 carb flange versions)
have GREAT potential for use with 2 4 barrel carbs on a carb adapter.
More power, much better drive-ability, lower cost. Much more tuneability.
Big 1300-1500 cfm max capacity, much more progressive.
Autopart101
Cougar5.0 wrote: Sun Jan 07, 2018 6:43 pm
Yes the Vic jrs are the weak point. The SV would work just fine. I just think the 2828 will do well on this size Windsor.
CGT
Post by CGT »
randy331 wrote: Sun Jan 07, 2018 6:23 pm
Maybe I can prove it to him? ?
