Ring groove spacers
rocketracer380
Ring groove spacers
Post by rocketracer380 »
Any one making ring groove spacers so I can run thinner rings on 5/64 pistons
Diodedog
Re: Ring groove spacers
Post by Diodedog »
Total Seal.
Alan Roehrich
Post by Alan Roehrich »
Talk to Keith or Kevin at Total Seal about their Advantage ring package. I use them exclusively in NHRA Stock Eliminator engines with excellent results.
PackardV8
Post by PackardV8 »
rocketracer380
Not about being obsolete it's about using what u have at hand and Makin it work better
PackardV8
Post by PackardV8 »
rocketracer380 wrote: Sun Jan 07, 2018 8:32 pm Not about being obsolete it's about using what u have at hand and Makin it work better
Din't mean to suggest you or your build was obsolete, just me and mine. Total Seal is great for the 4" and up bore guys with high budgets, but sometimes some of us need a low ball option and I included that link for us.
Krooser
Post by Krooser »
PackardV8 wrote: Sun Jan 07, 2018 9:22 pm
Jack... I've been obsolete for decades...
tenxal
Post by tenxal »
rocketracer380 wrote: Thu Jan 04, 2018 10:49 pmAny one making ring groove spacers so I can run thinner rings on 5/64 pistons
As Alan mentioned, contact Total Seal. This is commonly done on NHRA Stock Eliminator engines where the rules stipulate original ring groove width in pistons. Many of their spacers also have side gas ports, as well. Measure the ring groove depth in the pistons before you call them.
pamotorman
Post by pamotorman »
why not use oil ring rails ??
Frankshaft
Post by Frankshaft »
If you have ever used a total seal gapless top ring, that's what your using too.
Post by MadBill »
Not according to their site: http://www.totalseal.com/pdf/Installati ... 2010_2.pdf
"Do not intermix gapless ring rails with oil ring rails or
try to substitute rails from any other ring set.
Total Seal Gapless® rings and rails are carefully machined
to fit together and are not interchangeable with other Total
Seal rings or with any other rings not from this set."
Alan Roehrich
Having used and sold Total Seal Advantage ring sets for over a decade now, I can assure you tht the spacers are NOT oil ring rails, nor will oil ring rails work as well.. And the spacers are not like their gapless top ring. You can combine the spacers with their gapless top ring.
Frankshaft
MadBill wrote: Mon Jan 08, 2018 9:04 pm Not according to their site: http://www.totalseal.com/pdf/Installati ... 2010_2.pdf
What I meant, a gapless top ring set is basically a spacer with a much thinner top ring. I wasn't suggesting using pieces and parts to try and adapt to other applications. I was just pointing out that.
enginenut2
Post by enginenut2 »
I found the spacers I needed to fit a 3 3/4" bore Seagrave v-12 @ Wiseco. A user friendly phone call, reasonable, and they got them to me promptly. Years ago they would have been readily available from Perfect Circle. In many places they would have been called GI inserts and were many times used in re-ring jobs to repair top ring groove excessive clearance and to space the top ring down from the ridge in the cylinder caused by the previously used top ring.
PackardV8
Post by PackardV8 »
enginenut2 wrote: Fri Jan 12, 2018 7:00 pm I found the spacers I needed to fit a 3 3/4" bore Seagrave v-12 @ Wiseco. A user friendly phone call, reasonable, and they got them to me promptly. Years ago they would have been readily available from Perfect Circle. In many places they would have been called GI inserts and were many times used in re-ring jobs to repair top ring groove excessive clearance and to space the top ring down from the ridge in the cylinder caused by the previously used top ring.
For True. I've got a Perfect Circle kit, with the hand-driven tool to square up the worn grooves to accept the spacer rings.
