67RS502 wrote: ↑Thu Jan 04, 2018 11:00 am
EMC always has me thinkin...
Raise the rpm to say 7200-7500
Bit more head work
1 3/4" headers with small merge collectors
Good solid or HR lobes, no lift rule.
Would like to see how a Holley intake would match up.
intake spacers
I believe it would make 600hp just with more rpm
Would 625hp be doable?
Our emc engine made 460 LBs of TQ at peak HP rpm (6500 rpm), so if you could raise the TQ curve 500 rpm to 7000 rpm, and not loose any TQ doing it, it would make 613 HP.
A solid roller and no lift limit would go a long way towards that goal. A solid flat tappet @ .842" diameter and stock small block journal are very short on area compared to a roller.
If the rules had allowed solid rollers, no lift limit, carb spacers, and the scoring rpm was 4500-7500 I'd say our engine would have been in the 600-625 HP range.
Little more open carb rule maybe too.
But the rules were intended to resemble a street engine. How many build a street engine with TK lobes and 1.7-1.8 rockers and titanium valves ?
