randy331 wrote: ↑Tue Jan 02, 2018 2:11 pm
77cruiser wrote: ↑Tue Jan 02, 2018 1:34 pm
Would you make any gains with a roller keeping with the same peak RPM?
Yes mostly above peak TQ RPM.
I measured a 236* @.050" Comp Cams magnum hyd roller lobe with a 1.6 rocker on it that gave it the same .600 lift as our EMC lobes did with a 1.85 rocker. It's surprising how much more area it still had at the valve VS our EMC combo.
This was my initial thought . That if someone wanted to build a street strip motor
based on this they'd be much better off duplicating the net at valve motion and lift area using a street roller cam and appropriate rocker arm.
IMHO to fairly compare a (equally re-worked) dual plane against your good single plane manifold it would need its own optimized camshaft, to be its best. The top end power difference would not be so big in the top end yet retain all the torque. Then it would be fun to split some hairs as to which is actually better overall.
The dual plane will also tend to want a bigger carb..(or 2 x carbs)
EG: the Performer RPM air gap Dual Quad manifold.
The trouble with dual plane manifolds is they are much harder to re-work.
