gmrocket wrote: ↑Sat Dec 30, 2017 1:41 am
Yes I would be interested Randy.
What kind of low end TQ?
I used a Vortec 350 block bored .030" over and a Eagle 3.48 stroke crank.
Got sealed power hyper pistons with dish that took 1.5 1.5 3 mm rings. Used .030" file fit top at .019 gap.
Used a .020" file fit second and just dropped it in with no filing. It's .025" gap.
Used a .020"over expander under a set of .030 over oil rails for oil ring set.
Short block rotates over at 14 LBs.
The cam is hyd roller GM puts in the 383 HT truck crate engines. Part #14097395
196-206 / 109 LSA .431/.451 lift wiith 1.5 rockers.
Lifters are ls hyd rollers and springs are lS.
The heads are Dart #10024361 that were advertised as 165cc but were 170-171cc with the throat already out to %89.
I ported the heads some and went to a 2.02" Manley valve on intake and stayed 1.5 ex. With 50* seats on both.
Think about the lack of window area with a 196* @ .050" duration cam and .430 lift???
Did quite a bit of porting on ex. They had bad edges where valve job ended as they came from Dart.
Rockers are a set of self guided off Vortec heads.
Performer rpm cause I had 3 of them sittin here.
Dynoed with a 600 vacuum carb, but have went to a 450 vacuum secondary quick fuel.
It made 380 Lbs at 2000 rpm and was right around 400 Lbs from about 2300-3500 rpm or so. Right where the engine will run at hy speeds.
Made a few pulls with just the secondary side closed and it made no difference in power till after 3200 rpm, then was worth about 20 peak HP.
Brought the engine up to 2500 rpm and then added load and throttle till it was producing 100 BLs tq and it was still showing 17 inches manifold vacuum.
Peaks it made 405 LBs at 3000 ish ( hard to tell right where peak tq was cause it's very flat curve there ) and 310 HP at 4900.
Made a couple pulls on out to 5500 rpm and I have never seen an engines power tank so fast in just 500 rpm. LOL
