396 BBC. Nos
rocketracer380
396 BBC. Nos
Post by rocketracer380 »
Here's my combo 396 .060 ,12:5 comp 2 bolt main studded steel crank 3/8 rods 680" 714" solid roller ported square ports closed chamber 4.56 's and 4500 stall 9" lookin for 10.50's on motor and 9.50"s on a big shot plate @3400#
Re: 396 BBC. Nos
Post by pdq67 »
One way to find out is to gas her until she blows!
Will NOS like that high a CR? I don't know...
I suppose shim OR MLS head gaskets along with studs should be able to keep the heads from lifting??
Keith Morganstein
Re: 396 BBC. Nos
Post by Keith Morganstein »
rocketracer380 wrote: Tue Dec 19, 2017 2:55 am Here's my combo 396 .060 ,12:5 comp 2 bolt main studded steel crank 3/8 rods 680" 714" solid roller ported square ports closed chamber 4.56 's and 4500 stall 9" lookin for 10.50's on motor and 9.50"s on a big shot plate @3400#
How much does the car weigh?
How many different combos do you have?
F-BIRD'88
Re: 396 BBC. Nos
Post by F-BIRD'88 »
Needs a Hyd Roller
lefty o
Re: 396 BBC. Nos
Post by lefty o »
F-BIRD'88 wrote: Tue Dec 19, 2017 8:45 am Needs a Hyd Roller
maybe a 6bbl qjet!
Old School
Re: 396 BBC. Nos
Post by Old School »
TRW pistons? 5/64 rings?
I don't see 10.50's at 3400 with that combination on engine only. You will run better on nitrous comparatively than engine. The rect. port heads have a lot of volume for a 396.
F-BIRD'88
Re: 396 BBC. Nos
Post by F-BIRD'88 »
lefty o wrote: Tue Dec 19, 2017 11:06 am
maybe a 6bbl qjet!
Ahh, stealing my ideas already eh....
Thais is the engine that needs a tunnel ram.
DCal
Re: 396 BBC. Nos
Post by DCal »
Think along the lines of the NHRA B/SA classes.They can run low 10's with ease but they are highly modified motors so it probably depends on motor building abilities but the potential is there.
lefty o
Re: 396 BBC. Nos
Post by lefty o »
F-BIRD'88 wrote: Tue Dec 19, 2017 11:58 am
maybe a 6bbl qjet!
no point in stealing garbage!
Casper393W
Re: 396 BBC. Nos
Post by Casper393W »
If you spray it, I think you might run out of gear....
ClassicComp
Re: 396 BBC. Nos
Post by ClassicComp »
Been down that road with a 10.1 cr 402 BBC with 990 heads.
3750lbs ran 11.30's @117 470peak hp.
Sprayed with a Big Shot and a 200hp Dave Kohler tune ran 9.74@136.
Trw pistons,3/8" rods,cast crank,Engle roller cam,750 holley dp with a Proform Main body...
results speak for themselves
cgarb
Re: 396 BBC. Nos
Post by cgarb »
"no point in stealing garbage!"
One man's trash is another man's treasure...
lefty o
Re: 396 BBC. Nos
Post by lefty o »
cgarb wrote: Tue Dec 19, 2017 7:05 pm "no point in stealing garbage!"
that is correct, even if its a runny turd!
vortecpro
Re: 396 BBC. Nos
Post by vortecpro »
DCal wrote: Tue Dec 19, 2017 12:40 pm Think along the lines of the NHRA B/SA classes.They can run low 10's with ease but they are highly modified motors so it probably depends on motor building abilities but the potential is there.
"https://youtu.be/2KgAilTTZnQ"
rocketracer380
Re: 396 BBC. Nos
noI have had or currently have at any given time 5 to 10 engines that particular build is twenty + years old I never got to shoot it hard I shot my 358 at 12:1 comp stock block without issues so I don't see the 396 not takin a 350 shot with ease my friend had a similiar build only no solid roller went low tens @115 cutting gas do to the fact the car was all over the track. I also went a lo ten @ about 118 cutting gas I don't see a problem with mid to lo nines and I only shot 200 twisted an axle tube in a 69 camaro 3300# car the car ran. 11.0's on motor with a tunnelram and twin 660's thru 3 1/2 exhaust @3300#
