$10,000 To Buy and Build A Car...What Would You Build?
bigpoppapreston
Post by bigpoppapreston »
If you were given $10,000 to buy and build a race car, what would be your choice of car or truck and what combo?
-Poppy
prairiehotrodder
Re: $10,000 To Buy and Build A Car...What Would You Build?
Post by prairiehotrodder »
fox body mustang without question if its about going fast for cheap. Then a small block chevy engine with nitrous. It can easily weigh 2700 pounds or less.
GARY C
Post by GARY C »
prairiehotrodder wrote: Mon Dec 18, 2017 6:42 pm fox body mustang without question if its about going fast for cheap. Then a small block chevy engine with nitrous. It can easily weigh 2700 pounds or less.
Thats what I have and the amount I have in it.
The other option would be an F body because I have more experience with those and can be made to work with minimal $'s
bigpoppapreston
A Fox Body, SN-95 or New Edge Mustang or a F-Body would be competitive and cheaply ascertained. There are stock bottom end nitrous assisted 5.7 346 LS1 F-Body cars in the 8.90s. That probably would be very competitive for $10,000 total. A stock block 557 BBF with a used set of A-460 heads would be tough too.
-Poppy
Steve.k
Post by Steve.k »
In Canada be lucky to find car for 10,000!
Roundybout
Post by Roundybout »
A nice G-body with a junkyard LS, turbo 400 and a 9 inch. Maybe even a turbo if I could be frugal enough with that $10,000
Roundybout
Autopart101
Post by Autopart101 »
bigpoppapreston wrote: Mon Dec 18, 2017 7:13 pm A Fox Body, SN-95 or New Edge Mustang or a F-Body would be competitive and cheaply ascertained. There are stock bottom end nitrous assisted 5.7 346 LS1 F-Body cars in the 8.90s. That probably would be very competitive for $10,000 total. A stock block 557 BBF with a used set of A-460 heads would be tough too.
Wont even need a set of A head to get 890s. Uncles 3000lb 71 Cougar runs 890 560s with a 505 stroker. TFS heads flow just over 400cfm on the intake.
rfoll
Post by rfoll »
Something with a Chevy motor that isn't a Camaro or Nova. The price of those bodies in rough condidtion could easily eat your entire budget. You didn't say what you were going to do with it. For a street car, any of the later GM B bodies can still had for cheap. Big inch Olds, Buick, and Pontiac were stock. Many came with a 10 bolt using the 8.5 gears, huge brakes, and some with overdrive. Every time I drive this car someone pulls up next to me and gives me the thumbs up.
bigpoppapreston
Autopart101 wrote: Mon Dec 18, 2017 8:40 pm
I quoted 8.90s with a nitrous stock bottom end 346 ls1 as being a quick cheap combination. I am sure if one was frugal enough that they could find a nice set of second hand A heads, build a BBF stroker up to 557 and run faster than 8.90s and muscle. I just dont know if there would be any room left in the budget for a plate system. The BBF would really cook with A heads and a plate.
-Poppy
statsystems
Post by statsystems »
rfoll wrote: Mon Dec 18, 2017 8:47 pm Something with a Chevy motor that isn't a Camaro or Nova. The price of those bodies in rough condidtion could easily eat your entire budget. You didn't say what you were going to do with it. For a street car, any of the later GM B bodies can still had for cheap. Big inch Olds, Buick, and Pontiac were stock. Many came with a 10 bolt using the 8.5 gears, huge brakes, and some with overdrive. Every time I drive this car someone pulls up next to me and gives me the thumbs up. !cid_2BDF2E9B4CEB44CCBF1EB94D37F7C0BB@userPC.jpg
That's an old picture because that guy hasn't been the starter since about 1986-87.
