That would be the one.
Anybody try it or know anything about it??
John conversed with me about the treatment while he was conducting some of his testing.
There was an issue with detonation with as little as 20 degrees total advance on one of the test engines, but I believe he worked this out based on my last conversation with him.
Troy Patterson TMPCarbs.net TMP Carbs
fire slots in piston domes
- af2
Re: fire slots in piston domes
toddcalo wrote:Is there any advantage putting a fire slot in the dome in front of the spark plug, ( the plug is real close to the chamber roof,however heads have been angle milled .200 ) dart iron eagle head with .400 dome ht?
The advantage I have is the dome not hitting the ground strap on the plug.
GURU is only a name.
