Engine assembly techniques
mag2555
Re: Engine assembly techniques
Post by mag2555 »
I love that guy who runs off with the Intake Manifold like stole a Millon bucks, what up with that when everyone else seem to just tossing parts to the side?
Krooser
Post by Krooser »
What happened to the days of using a speed wrench?
Kenova
Post by Kenova »
I wonder how often the poor bugger on the bottom end gets stepped on.
Ken
Over the hill but still learning!
Retaining it is the hard part.
Roundybout
Post by Roundybout »
is there anything that doesn't get removed? Other than looking at them cam bearings maybe?
Wow there's a lot going on there. I take it the guy on the bottom end is the new guy? lol
shoedoos
Post by shoedoos »
Just watched the whole thing.....made me wonder if the crew thinks "damn, they beat us" every time a fuel car warmed up while they were still tearing the thing apart?
Keith Morganstein
Post by Keith Morganstein »
That's typical, at least from what I've seen and been told by a friend who's crewed on TF and FC teams
BTW, the ball hone was after the pulled the sleeves out. Cleaning the sleeve bores. Fresh clean sleeves are installed.
Keith Morganstein
I just checked with my bud about it.
His team would ball hone sleeves in the block and wash with brake clean. He was the bottom guy. Said he got stepped on, nitro all over him, hot oil and threw away a Walmart t shirt between rounds. He said the new guy washes parts. Lower end guy is known as a diver and is just as important as the guy washing parts. Engine runs a max of 5 minutes between rebuilds, so no need for precision. They torque the heads from the outside in. It takes 35 minutes for what they call a "turn around".
SupStk
Post by SupStk »
Take another look Keith. The front two sleeves were replaced the back two were dingle balled.
Don't have to worry about too much cleanliness if the engine comes back apart after a few seconds of run time...:D
Monty Frerichs
B&M Machine
LSP
Post by LSP »
If one of those sealed properly, you could reduce the fuel pump volume a ton..
I once talked to one if the top fuel crew cheifs for a good bit at a party a few years back. I asked about fixing the sealing issue they have, and he said they can't make any coarse changes regardless of the potential benefit, as the small changes they make already throw them into a big learning curve sometimes.
77cruiser
Post by 77cruiser »
It on turns over 500 or so revolutions under full power anyway.
Jim
